Stranded!!! No start - Ford Powerstroke Diesel Forum
post #1 of 18 Old 01-12-2013, 09:08 AM Thread Starter
Wyoming6.0's Avatar
So I'm driving through town and my pickup just dies. No warning or nothing. Got a p0261 and p2290 codes. It'll crank but no start. Any ideas?
Sent from my iPhone using AutoGuide.com Free App
Wyoming6.0 is offline
post #2 of 18 Old 01-12-2013, 09:09 AM Thread Starter
Wyoming6.0's Avatar
My cell is 307 941 0881 fastest way to get ahold of me. I'm stuck in Sheridan Wyoming bout 3 1/2 hours from home
post #3 of 18 Old 01-12-2013, 10:40 AM
A quick try you can do is unplug the ICP sensor and try to restart, if it starts and stays running leave it unplugged and drive home. Then look at running some of the tests in the stickies.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #4 of 18 Old 01-12-2013, 10:43 AM Thread Starter
Wyoming6.0's Avatar
Ok my icp sensor is on the front of my passenger side valve cover right?
post #5 of 18 Old 01-12-2013, 10:52 AM Thread Starter
Wyoming6.0's Avatar
Tried it. Still nothing
post #6 of 18 Old 01-12-2013, 11:46 AM
Powerstroke Techie
Quoted: 318 Post(s)
what year? does the oil pressure gauge rise when you're cranking?
the richest ones are not those who have the most, but those who need the least
kaya is offline
post #7 of 18 Old 01-12-2013, 11:49 AM Thread Starter
Wyoming6.0's Avatar
It's an 06 and no oil pressure while cranking. But before when it was running the gauge wouldn't read any pressure until just after it fired up. Read my icp voltage and got .23 volts with key on and while cranking. Is that good?
post #8 of 18 Old 01-12-2013, 12:07 PM
Powerstroke Techie
Quoted: 318 Post(s)
no, that's bad. that's very low icp. only possibilities for that low of icp when cool is a completely blown stc fitting, ipr valve stuck open, or bad pump (05+ pumps don't usually fail, but is not unheard of).
were you previously ever having any trouble getting the vehicle started hot?
kaya is offline
post #9 of 18 Old 01-12-2013, 12:19 PM Thread Starter
Wyoming6.0's Avatar
Haven't had any problems with it starting when warm. Haven't had any problems actually. Just up and quit while running about 30 through town. No warning no sputtering or loss of power. Nothing.
post #10 of 18 Old 01-12-2013, 12:43 PM
Powerstroke Techie
Quoted: 318 Post(s)
hmm. yeah it's also kind of odd that you would have a p0261 along with this. that usually points towards a ficm or injector circuit issue. but low icp shouldn't cause that and vise versa. maybe 2 separate issues? or are they connected? hmmmm
kaya is offline
