won't start,dealer making me uneasy - Ford Powerstroke Diesel Forum
post #1 of 8 Old 11-09-2007, 08:00 PM Thread Starter
04' with k/n filter and no mods
won't start after it was drivin to work . had it towed to dealer they did a compression test after hearing the starter spun real high.#1 cylinderhad only
60lbs. only have 43,000 miles on it. it ran out of fuel 3 days before from a bad fuel gauge but ran fine after.dealer says its modified with the air filter and warranty could be in ?void the warranty from an air filter?
racefreak04 is offline
post #2 of 8 Old 11-09-2007, 08:04 PM
Click Click.......BOOOOM!
matt1030's Avatar
I think you need to find another dealer!! Post where your from maybe somebody knows a better dealer in your area!!
2012 F-350 6.7L 4X4 FX4
Lariat SuperCab Shortbed
matt1030 is offline
post #3 of 8 Old 11-09-2007, 08:07 PM
HorseMover's Avatar
Quoted: 29 Post(s)
Where are you located?
2012 F-350 CC Lariat Dually
HorseMover is offline
post #4 of 8 Old 11-09-2007, 08:19 PM Thread Starter
located in new jersey,dealer says shes giving me the worst case synario
post #5 of 8 Old 11-09-2007, 08:31 PM
matt1030's Avatar
I don't know if i'd trust them over an intake. I've got alot more done to mine and just had the turbo replaced under warranty. I'd call around to some other dealers and talk to the techs or maybe someone here knows a good place to take it.
matt1030 is offline
post #6 of 8 Old 11-09-2007, 08:45 PM
Take it to Hackensack Ford. Ask for Ken to write it up and for Richie to work on it. Tell em Bruno sent you. They know what they're doing.
2002 F350 7.3L PSD HO SCLB HD 4X4 6-SPD LS 3.73
Bilsteins, Mag-Hytec Diff. Cover, FS-2500 Bypass Filter, Billet T-Stat Housing, 203* T-Stat, 4" MBRP SS TB, B&W GNTB.
2006 Jeep Liberty CRD 4X4 Some Mods.
2003 Cobra Coupe
DocB is offline
post #7 of 8 Old 11-10-2007, 08:39 PM
DoubleDpsd's Avatar
don't talk to women at dealers about service. Tell them THEY HAVE TO PROVE IT WAS THE K&N to void your warranty. know your rights. mm act.
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #8 of 8 Old 11-11-2007, 08:10 AM
i dont see 1 bad cylinder causing a no start all the more reason to take it somewhere else.
pa444 is offline
