Blue Spring Install Now hissing sound
I have a 03 6.0 decided to install the blue spring today, put it all back together now theres a hissing or sucking sound coming from the area.It happens when the fuel pump turns on and when the truck is running, Any thoughts? Suggestions? would be greatly appreciated
Did you keep the white air-bleed in place on installation or install a new one?
I installed the one im pulling it back apart and checking it
still hissing everything is put back together right ,no fuel is coming out anywhere and still hissing any other suggestions? This is the key on not started
If it is correctly installed and there is no crack or loose fittings, you should not hear much. However, it may possibly be turbulence across the relief orifice, if it is not seated completely. What is your fuel pressure now both KOEO and running idle and WOT?
I dont have a fuel pressure gauge right now, i know i know , i need to get one asap and i didn't want to run the truck with the hissing, I am using the old o ring and fuel filter just to test it and they both are good, everything seems to be seated correctly, I just cant pin point where the exact hissing is coming from i know its form that area though, anything i can try doing? thanks for the help
Now the hissing sounds like its coming from inside the housing
| Tags |
| blue spring, fuel pressure regulator |
