10 of 2005 F-550 Power Stroke NO START - Ford Powerstroke Diesel Forum
post #1 of 14 Old 01-11-2013, 03:55 PM Thread Starter
Ive got a 10 of 2005 ford f-550 power stroke diesel with only 53000 well taken care of miles. All of a sudden one day truck will not start,,spins over normal and seems like its going to start but sorta kicks/snaps as its gonna fire but then dont and if you continue to spin over it will not do anything. During the snapping/cracking like its got a short or something its pushing allot of black out tail pipe. If you try it maybe 10-20 times all of a sudden its fires and if you dont shut it off it runs and drives perfectly. Shut it off and it will start over and over again,,let it sit overnight and its a 50/50,,may fire but most likely will not and starts the same deal all over again--turn over it cracks/snaps/while black stacking out pipe then spins and dont do anything. If you get it running like i said it runs perfect. Oil and filters are resent,,no codes at all,,nothing. Any help apreciated greatly,,Thank You!
1290pine is offline
post #2 of 14 Old 01-11-2013, 06:16 PM
460+'s Avatar
You could have a blown dummy plug or feed tube blown letting oil to bleed by.
99 F350 4x4 dually
7.3 w/K&N af
4" exh into 6" Aussies stacks
4"lift &35" tires
CC mod HP crossover line
Beans stage II 120hp injectors
D66 turbo
ITP regulated return
reburn on TS= 25,high idle,60,100,120,140hp
updated ecm (2000 model)
Dyno#'s 360hp and 965 ft lbs trq
460+ is offline
post #3 of 14 Old 01-12-2013, 03:48 PM Thread Starter
today after sitting all night, turned key--snaped cracked for and i mean a split second and fired up an runs fine. i can tell its going to do it again garenteed,,any other ideas??
1290pine is offline
post #4 of 14 Old 01-13-2013, 04:17 PM Thread Starter
tried again today and fired right up no issue,,i know its going to do it again
1290pine is offline
post #5 of 14 Old 01-13-2013, 04:35 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Is it stock? Does it still have the EGR valve?
dhanna6powerstroke is offline
post #6 of 14 Old 01-13-2013, 04:39 PM Thread Starter
This truck is all stock,,nothing at all is altered. Low well taken care of miles.Trucks literally a puff.
1290pine is offline
post #7 of 14 Old 01-13-2013, 04:42 PM
Mod Newbie
Quoted: 20 Post(s)
Pull the EGR valve and clean it. That could be what's causing the black smoke and your no start.
post #8 of 14 Old 01-13-2013, 04:49 PM Thread Starter
The darn thing whene it wont start its as if its shorting/snapping ect. then perfect--nothing out the pipe start and runs great. I have been reading some on the ficm??
1290pine is offline
post #9 of 14 Old 01-13-2013, 04:51 PM
Mod Newbie
Quoted: 20 Post(s)
Your first post said it's pushing a lot of black smoke. Have you checked the FICM voltage?
post #10 of 14 Old 01-13-2013, 04:57 PM Thread Starter
Yes black smoke when its at the no start stage,,it black stacks only whene it cracks and attempts to fire sorta as if wrong timing or something,,if you never stop turning the engine over it will stop that and do zero but spin and spin and spin. Leave it overnight and it may start like the day it was born,,no smoke,,no cracking//snapping smoke nothing..drive it its fine shut it off it fires no problem,,yet leave it and its 50x50 if it will run or not. no didnt check ficm voltage but in morn i will.
1290pine is offline
