blown head gasket - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-09-2007, 03:35 PM Thread Starter
blown head gasket
Just took my 05 F-250 6.0 with 70,000 mi to the dealer this afternoon with steam coming out of the exhaust. The dealer will let me know tomorrow if the head gasket is blown. My question to you guys is this a common issue or is this just a rare deal. Is there a fix I should know about? The steam seemed to go away after I ran the truck real hard but came back during normal driving. I await your reply.
Henry
henry is offline
post #2 of 7 Old 11-09-2007, 03:38 PM
rankroddin250's Avatar
could be streached head studs or a bad egr cooler? hard sayin. either way hopefully your warantee covers it.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
The People of a free country should not be scared of their government, the government should be scared of their people.
rankroddin250 is offline
post #3 of 7 Old 11-09-2007, 03:41 PM Thread Starter
give more info on the studs and EGR cooler> This motor has never been apart.
henry is offline
post #4 of 7 Old 11-09-2007, 03:52 PM
the factory head bolts can stretch causing the head gaskets to leak. usualy cured by a good set of ARP head studs.
the egr valve sucks exhaust back through your motor and burns it twice to reduce emisions. your truck as an egr cooler which uses the engine coolant to cool the exhaust gasses down before recirculating it through your motor. if those go bad it will dump coolant into your exhaust like your describing.
is it puking coolant out of your coolant reservour after you get on it hard?
post #5 of 7 Old 11-09-2007, 03:55 PM Thread Starter
No the overflow tank appears to be working like it is designed (raises when hot and lowers when cold).
henry is offline
post #6 of 7 Old 11-10-2007, 12:15 PM Thread Starter
blown head gasket
Got a call from the service manager late last night. The issue is not a blown head gasket but is the EGR cooler. Thanks for all the feedback.
Henry
henry is offline
post #7 of 7 Old 11-10-2007, 08:40 PM
DoubleDpsd's Avatar
try to have them replace the oil cooler also and look into installing a coolant filter. http://www.dieselsite.com/index.asp?...ROD&ProdID=324
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
