Puking Stopped??? - Ford Powerstroke Diesel Forum
Old 11-09-2007, 07:59 AM
Puking Stopped???
When these engines start puking, do they do it all the time? I noticed mine had something around the overflow reservoir cap, but it was a day after I washed it, I might've just not sprayed the degreaser off good??? I wiped it off and have probably drove 50 miles since then and (knock on wood) nothing is coming out now
Old 11-09-2007, 08:04 AM
I don't know nuttin....
Good deal!
Old 11-09-2007, 10:34 AM
Slacker
Feedback Score: 4 reviews
No, they don't puke all the time. It's usually under a good load when they'll puke, either due to a hot tune and a heavy foot or an early indication of an EGR cooler failure. If this was the only time you've seen the white crusty on the bottle, I wouldn't worry about it. If this is a consistent problem, you should investigate it.
