lost 10 qts oil threw vgt sensor port now crank no start
Had bolt off vgt sensor on turbo which was having issues then the sensor got blown out and out came 10 qts of oil.truck instntly died.topped off oil replaced sensor and no start.ficm has 46.5 volts.fuel at filter on motor.oil flow at filter.when I crank over oil pressure gauge shows pressure after about 5 sec of cranking.no codes.chenged sct tune back to stock. Would my oil pressure gauge in truck show pressure if my hpop was bad? I don't smell fuel out of exhaust after cranking
I think the gauge on the dash only needs to see 10 psi to give a reading, so you can't really trust it
If the truck died, then you probably lost all 15 qts. If the truck died due to oil loss, you got air into the hpop, oil lines, and injectors. Then you'll need to crank for a while to crank out all the air and get in oil.
I made my Samsung SGH-I997 send this. |
Thanks ....ill try cranking it more...
Is it possible that I damaged the hpop?
U were right it was air locked....I cranked ova for a solid 30-45 sec.and she fired up
Run it hard, get the air out.
Thanks again for the help....trucks running good and I believe I fixed the original turbo problem by replacing the sensor on the top of the turbo,the one that almost looks like a injector,I think its called a.vgt sensor ?it was $308. From ford.now I'm going to flush out.coolant and replace with the cat coolant and also I wanna change to synthetic oil.
