How to pull 6.0 in 2004 F-350
I was curious to know if the front grill/front clip come off to pull the motor, or if there is enough room come out up and over. The problem is I have a front bumper, grill guard in the way that probably weighs a ton.
The "easy" way is to use a twin post lift to lift the cab off the chassis. Then roll the chassis back to service the engine. This is how most shops do it.
I have a standard engine hoist. Can I make this work?
jeeze I cant see how like seawolf said most places lift the cab off the truck, well thats the only way that Ihave seen it done
Yes, pull the front clip off and it will come out.
You need a lift to ge the cab off. |
Ok. Where do they hook up to the cab as well as the engine? What has to be disconnected from the cab?
I would say that everything has to come off of the cab, anything that goes from the frame/cab that is attatched to the engine, this is a pretty involved job
hey MTMAN check out dp page 162 they do a full right up on pulling the cab/engine on a 6.0
