head gasket - Ford Powerstroke Diesel Forum
Old 01-07-2013, 03:59 AM
head gasket
any one ever see a head gskt go bad on a 6.0 i have one here less than 50000 miles it fills the muffler with coolant any tips thanks
Old 01-07-2013, 04:04 AM
Is the egr still in it? If so you may want to investigate that first.
Sent from my HTC One X using AutoGuide.Com Free App
Old 01-07-2013, 04:16 AM
egr is still in this truck is there any way to check the egr cooler
Old 01-07-2013, 05:03 AM
Park the truck with the nose downhill pull the egr valve and look for signs of wetness. If that is present the egr is most likely ruptured. The majority if the time the egr ruptures due to the oil cooler being clogged. In order to diagnose head gaskets both of them need to be in working order.
Do you have a monitor on the truck? If so what were eot and ect?
Old 01-07-2013, 05:05 AM
Take a few minutes and read the stickies, a few 6.0 head gaskets have failed here and there. Need a tip, immediately stop running it before you bend a rod. Get a monitor on the truck, before you get it repaired and running again.
Sent from my phone that somebody didn't help me get.
