Truck wont start
This isnt my truck im posting this for someone.
It is a 2006 f250 6.0 over 100k miles. The truck staled a few days ago and the WATER IN FUEL light on the dash came on. Drained the water out, replaced both fuel filters while we were at it. WATER IN FUEL light went off, but truck wouldn't start. Forgot to bleed the air. So we bled the air out, still no start. There is no air left in the lines. We used some ether to start the truck, which did start it. The truck would only stay on when reving over 3000 rpms, anything under that it would stall. We left it running like that multiple times and still stalled after. So a mechanic came in and hooked his computer up and it said COMMUNICATION PROBLEMS. Im thinking now that the water in fuel light was lit up because of problems with the PCM or a sensor(s), and not even a problem with water in the fuel. Water in the fuel wouldnt of caused it to stall anyway right? im not sure on that. Does anyone know what could be causing this? Any certain sensor that would not let the truck start or stay on under high RPMS? Truck ran fine before this and just stalled one day and has been being a typical 6.0 ever since. Any help would be great, thanks |
Try unplugging the icp sensor and see if it starts. That sensor is probably the most replaced part on a 6.0 If you unplug it the FICM goes into a preset mode and it will run if it is the sensor that is bad. My truck died recently and it turned out to be the FICM. One of the codes it threw was the communication issue. I have not gathered all the parts to get it running again so can not say for sure that the FICM threw that code but I never saw a check engine light before so apparently all the codes came on at the same time. Hopefully it is not your FICM but I am guessing at this point that there can be some connection between the communication code and the FICM.
Alright ill unplug that and see if it works. It does seem like a fuel problem and the injectors themselves shouldnt be bad... Whether it is the FICM or ICP idk, but as of now thats the best bet, ill try it and get back to the thread. BTW this might be important to add in, the truck runs strictly on off-road fuel. Not my truck so plz dont give me crap for it lol.
Thanks for the help, and if anyone else has any ideas id appreciate the input. Thanks |
let's start with the communication issue. when you cycle the key on, do the warning lights on the cluster illuminate briefly? if they do, check the cig lighter/aux power fuse. it supplies power to te diagnostic port. 90% of the time, no comm with the scan tool is caused by the cig lighter fuse being blown.
or did he mean the truck was throwing communication codes? was he able to interface with the trucks network? |
Thanks for that information. When my FICM blew and I pulled codes I got a P0265, P0268and a V0155. Someone somewhere along the line respoded that there are no V codes and I have not seen a V code on any code chart. Their best guess was that my scanner is not totally compatable with the diesel and is probably misreading something. It did however read on the scanner no communication with instrument cluster.
Is the aux power fuse in the box behind the panel under the steering column and what type fuse is it? Long story but I finally have all the parts to get mine running again I just need find the time to make the hundred plus mile trip to where it is at to bolt everything back on. I will check that fuse because not knowing for absolute certainty where the voltage spike came from that took out the FICM I want to check all possibilities. Not looking for a rematch. |
if the aux fuse is blown, it won't allow comm between the scan tool and ANY modules. not just the IC.
but the fuse should be a 20amp mini. don't recall the exact fuse position, but yes, it is in the dr. side knee panel |
Never occurred to me that the code could be the scanner not communicating with the IC. I was thinking that the engine or? was not communicating with the instrument cluster. I have another $750.00 worth of parts in the trunk of my car waiting for a break in the schedule to drive up to the mountain to put them on and hopefully get this thing running. The prevailing wisdom is that it was all because of a voltage spike, probably from the alternator but I don't want to take any chances with ANYTHING. I don't want this truck dying again on the way to the chevy dealer
Ill know tomorrow if its the ICP sensor. Ill check the fuse to. Also someone just told me there is a security feature that doesnt let the truck start without deactivating it. Idk why it would throw a code if it was that. And nothing was done for the truck the go into a security mode. I just have to start eliminating possible problems tomorrow. Thanks guys idk much about these 6.0's i own a 7.3 just trying to help someone out. |
Wasn't the ICP sensor. Just going to take it in to ford dealer and see what they have to say. Ill post what the problem was when it is fixed. Thanks tho guys
