No boost coming from turbo!! VGT solenoid? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-03-2013, 03:59 PM Thread Starter
I have an 05 f250 with the 6.0. I was having problems with my truck sounded like the injectors were bad. It ended up being the FICM I replaced that and the truck ran great. But now my problem is the turbo would not boost at all. Then today driving it all the sudden started running great kicked up was boosting 15psi. At this point I drove home ran great I turned it off and then went to go and now only boosts like 3 or 4 psi. There is no leak first thing I checked was thinking maybe the VGT was getting stuck and ideas would be great!! Sorry if you need more information please let me know this is my first post..
ccracer13 is offline
post #2 of 9 Old 01-03-2013, 04:53 PM Thread Starter
Also this might help I took it out just now same problem no boost but if I power threw it up to 3k rpm's the turbo kicks on like normal and runs fine till I shut it off. Works when I stop go left it sit for 10 min then drove was fine. I stop the truck does it again till I hit 3k
post #3 of 9 Old 01-03-2013, 07:02 PM
southend's Avatar
It is likely your turbo needs to be pulled and cleaned.
Sent from my phone that somebody didn't help me get.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #4 of 9 Old 01-04-2013, 06:26 PM
i had a similar problem with mine it cant hurt to clean ebps/tube/elbow, mine was plugged solid and ran like *** til i got all the junk out.
Mark
04 -rclb
RCD EGR Delete
Sctx3 with tunes from Vivian
Xdp coolant Filter
Global charge coolant
5" MBRP
MarkBart is offline
post #5 of 9 Old 01-21-2013, 05:53 AM Thread Starter
sorry my computer died on me. But I have noticed that if I start my truck and put it in neutral and rev it up past 3k RPM's the turbo will spool right up and work till i turn it off. But I was wondering is there a sensor that could be bad because it is right at like 3k when it kicks in every time.
post #6 of 9 Old 01-21-2013, 06:01 AM
southend's Avatar
Re: No boost coming from turbo!! VGT solenoid?
Lol, it took 17 days to charge your computer.............jk. Check the map sensor hose and port that connects on the right side of the intake for tears in the hose and clogging.
southend is offline
post #7 of 9 Old 01-22-2013, 06:41 AM Thread Starter
Thanks I will check that tonight. And the computer died died like had to get a new one.. I also figured I forgot to say this happened around the same time i changed my FICM "Fuel Injector Fuel Module" Do you think it is the sensor or the tube or wire.
post #8 of 9 Old 01-22-2013, 07:13 AM
southend's Avatar
The tube and/or the nipple on the intake are prone to clogging. Some have had to change the sensor, but it is uncommon. Never heard of bad map sensor wiring, it is mounted up out of the way.
southend is offline
post #9 of 9 Old 01-22-2013, 01:19 PM Thread Starter
Thanks I will give that a shot tonight and let you know tomorrow. Thanks for the ideas
