oil in turbo on side of road - Ford Powerstroke Diesel Forum
Old 01-02-2013, 06:00 PM
Thought I had prob fixed when I cleaned map sensor.ran good then started having turbo problems again.turbo blew out sensor and puked a lot of oil out.is it a bad turbo seal?
Old 01-02-2013, 06:34 PM
Can you explain? Turbo blew out a sensor, and oil is leaking?
Sent from my phone that somebody didn't help me get.
Old 01-02-2013, 09:29 PM
hmmm. could be the turbo oil drain is restricted
Old 01-03-2013, 09:19 AM
I cleaned the sensor on the turbo the other day then truck ran fine .slowly I noticed more oil burning than normal on cold starts.last night I was driving then turbo started not building boost at low rpm when I floor it built boost fine which is not the same symptoms it had originally,so I pulled ova and pulled out sensor and cleaned.when I got back on road ot showed the original symptoms that were turbo was spoiling but boost wasn't getting to engine,a lot of.turbo bark.it was then that it blew the sensor out of turbo and blew out at looks like a qt of oil.as of last night truck wouldn't start again.the sensor has a steel bracket to hold in,I didn't have that installed in case I had to pull ova and clean again probably a dumb move but it was extremely cold last night
