oil change gone wrong? - Ford Powerstroke Diesel Forum
post #1 of 23 Old 01-01-2013, 11:09 PM Thread Starter
rlasher0066's Avatar
hey guys,
I cant figure it out so im wondering if you guys have any imput i have an 03 6.0 with 123k stock besides 4 inch turbo back. I changed my oil for the first time on saterday (bought the truck 4 months ago). any way after changing the oil now my truck will not rev above 1000rpms while cold. it has to warm up untill i can move it at all but once its warm it runs fine... im stumped i added just over 15 quarts of 15w40 and a motocraft filter. does anyone have any idea where i should start to diagnois this.
Thanks in advance
-Ryan
rlasher0066 is offline
post #2 of 23 Old 01-02-2013, 12:54 AM
Quoted: 2 Post(s)
What is your temp range where you live? And what do you mean will not rev over 1k rpm? As in full throttle will not go past 1k or the computer is limiting it? The oil seems thick to me. What brand of oil? Synthetic/non?
Troy K.
2003 Ford F-250 6.slow w/240K
4" Turbo back exhaust
SCT X4
XDP coolant filter
Blue Spring
315/75 BFG MT's on American Racing rims
Leveled
5100's
And way more time and money invested than its worth
Turk.919 is offline
post #3 of 23 Old 01-02-2013, 04:22 AM
southend's Avatar
That oil seems thick for up north right now. Are you sure your oil filter cap is oem?
http://www.dieselfiltersonline.com/f...k-filters.aspx
Alot of us are having good results with rotella t6.
Sent from my phone that somebody didn't help me get.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #4 of 23 Old 01-02-2013, 04:36 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Gonna jump on the thick oil band wagon. I just got rid of the 15-40 and went with the t5 10w30. Synthetic blend. The trucks cold start habits are totally improved.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 23 Old 01-02-2013, 04:43 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Oh yeah and welcome!
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #6 of 23 Old 01-02-2013, 05:17 AM
dnf12908's Avatar
Quoted: 31 Post(s)
I would never put 15W40 in a 6.0.
Darrell
'03 F-350 6.0L C/C SB FX4 SRW
SCT X3 w/tunes by MKM
MBRP exhaust-turbo back
EGR delete
ARP studs
OEM gaskets
ELC coolant & filter
MTW Stage 1 turbo w/billet wheel
FPR (blue spring)
'04 upgraded front cover
BPD fan clutch adapter/w 7.3 fan
stator delete
All-aluminum intercooler(upgraded OEM unit)
Amsoil bypass oil filter
Insight CS monitor
Harley headlights
2008 rear diff. cover
EnviroSave powertrain treatment,
dnf12908 is offline
post #7 of 23 Old 01-02-2013, 05:26 AM
ZMANN's Avatar
Quoted: 1564 Post(s)
5-40 t6
24-7-365 days a year for Me LOL
I find it funny that it won't rev but it did follow your oil change so IDK ?
We Miss you Ronnie
ZMANN is offline
post #8 of 23 Old 01-02-2013, 01:09 PM Thread Starter
hey guys
thanks for all the responses and yeah thats what my buddy told me to run soo i did (15w40). but as for the rev problem it wont rev with a load on it while cold. example. in park truck will rev normal but in Reverse or Drive you can put the pedel to the floor and it wont go up past like 1k.. im thinking maybe sence the oil is thick and its currently 19 degrees here and the injectors are oil driven that its just not flowing right untill warm?
post #9 of 23 Old 01-02-2013, 01:21 PM
I use Amsoil 5w-40 all yr here in NJ...seems most ppl are now runnin a diesel complient 10-30 or5-40 all yr now...easier on the engines...
Sent from my ADR6400L using AutoGuide.Com Free App
-Mike-
2006 F-350 Lariat, Supercab, 6.0L, 3.73's...Rhinolined Bed...6 Spd Handshaker...Mag-Hytec Diff. Covers...Smoked Recon Lights...Amsoil oils front 2 back...Optima Yellow Tops...MBRP 5" ST8 Pipe, Turbo Back...Dieselsite Coolant Filter...Amsoil/Injen CAI...SCT SF3 Canned Tunes 4 Now...CFM Intake Manifold and Boost Tube...Blue Spring Upgrade...Edge Insite CTS !!!
pete37922 is offline
post #10 of 23 Old 01-02-2013, 01:26 PM
southend's Avatar
Sounds like you may have a bad case of stiction and the heavy oil is not helping. Do your truck a favor and try t6, and rev-x or archoil 9100. Do you have a monitor?
southend is offline
