Ford 6.0 oil problem - Ford Powerstroke Diesel Forum
Old 12-31-2012, 05:15 AM
Hello new to the site. Got a stumper here!
2003 ford 6.0 customer cooked 3 turbos and finally brought it
To me
I found has 30psi low oil pressure and when u rev it up drops
To 10psi or lower then slowly returns to 30 psi at idle.
Removed lpop and has little scratches on front and back of gerotors
And housing has scratches
Ford oil filter and cap oem
No high pressure leaks found when pressure testing
Need help thank u
Old 12-31-2012, 05:34 AM
Time to change that pump and the front engine cover it sounds like.
Old 12-31-2012, 05:39 AM
Illiana Chapter Director
Needs new LPOP and front cover.
Old 12-31-2012, 05:47 AM
I was leaning towards that but just don't understand how it has oil pressure at idle unless it sucks air when off idle
Old 12-31-2012, 06:35 AM
If the pump flutters or cavitates (creates turbulence) at higher RPM it will not be able to move enough fluid.
Old 12-31-2012, 01:06 PM
Powerstroke Techie
Feedback Score: 3 reviews
or you could have a lifter starting to wipe
Old 12-31-2012, 05:46 PM
What can I check with lifter is bad it idles smooth when warm has some Striction on some injectors
