help 6.o wont start - Ford Powerstroke Diesel Forum
Old 12-29-2012, 03:04 PM
help 6.o wont start
please help i have a 2005 ford powerstroke that i bought figuring the ficm or hpop was down got home and started testing and the hpop was down i replaced that and updated fitting along with ipr and icp ficm test out to 47 v cranking injectors cycle hpo is 1300 i believe some one told me that it was still the ficm i put another one on same thing befor was saying ficm sycn yes crankpos campos syn no now after i switched its saying no to both put the old one back on and still saying no to both i have a new cam and crank sensor coming tomorrow could this be what it is please help
Old 12-29-2012, 03:48 PM
Send a message via Skype™ to Bluedemon6.0
Are you getting fuel in filter? what is your fuel pressure? Are you throwing any codes? Do you have a monitor?
Sent from my PG06100 using AutoGuide.Com Free App
Old 12-29-2012, 05:06 PM
good fuel pressure acording to scan tool i believe it was 45 psi but no codes at all
Old 12-29-2012, 06:22 PM
Glow plug relay?? Should shoot a code though while cranking
