Engine block heater keeps popping the breaker... - Ford Powerstroke Diesel Forum
Old 12-29-2012, 02:38 PM
Hey guys, any advice would be great!
I have an 07 F250 Lariat with the factory heater setup. I plug the cord in every night because it gets down around 0 degrees... I've noticed that if it rained or snowed during the drive, the breaker pops instantly or within 30 seconds. It never happens if I have driven on a dry day, so I'm assuming that something is getting wet and causing the current to connect.
Please guys, any advice on how to avoid this would be great. I HATE hearing the truck crank over in 0 degrees each morning!
Sent from my iPhone using AutoGuide.com App
Old 12-29-2012, 02:58 PM
breaker pops or a GFI in the same circuit ?
Old 12-29-2012, 03:02 PM
GFI, sorry for not being clear.
Old 12-29-2012, 03:18 PM
GFI's are super finicky specially on a load like a heating element
so a drop of water anywhere will cause an issue
your trucks connections should be water tight up until the connector plug to the extension cord ,, if u can keep that dry and it still trips I would double check the water proof caps at the element and cord to plug transition
also search Marinco Mod ,, very usefull
