New injector ?? - Ford Powerstroke Diesel Forum
Old 12-28-2012, 03:40 PM
New injector ??
Ok so I had 8 new (reman) 155 cc injectors installed now I'm getting intermittent rough idle & PO 269 code I wiggled harness at #3 while idling rough no change my question is this code is for electrical side of injector correct or could it be something else? Fresh oil change at install 5w40 t-6 thanks for any help !!!
Old 12-28-2012, 03:49 PM
That is not necessarily an injector code, did you do the install?
Sent from my phone that somebody didn't help me get.
Old 12-28-2012, 04:05 PM
No installed by quality local shop ,what else could cause this code was not pulling code before install they and the injector shop are closed until 1-3
Old 12-28-2012, 04:11 PM
A leak at the oil rail maybe, a copper seal, fuel injector oring, bent valve, burnt valve, cracked valve, cracked ring, maybe just a bad injector, just to list a few. Don't stress out too quick, clear it, and watch it, see if it comes back or clears up. I just listed some things that may also have nothing to do with it.
Old 12-28-2012, 04:16 PM
Check your pm.
Old 12-28-2012, 04:23 PM
I've cleared the code twice !! I've also noticed some times when I let off the skinny pedal to come to stop or slow down the rpm's stay just under 1000 other times it'll drop right down to 690-700 ?? Don't know if this is related but this also just started since injector install
