fuel sample pics-
Drained the FCM today. Last time it was drained? I have no idea. Ive had truck for 7 months and today I realized I had never drained it...(I did replace the filters but do not remeber taking the plug out, forgive me Im new here
.Anyways here is the pics what do you think? ![]()
I would pull that filter, inspect it, clean the housing. Reinstall and monitor closely. It wouldnt hurt to also pull the small side cover off and clean it out.
Sent from my phone that somebody didn't help me get. |
I will do that for sure on my next days off. Is this alot of trash or normal?
That is why the HFCM is the lowest point in the system with the big filter and the water/junk/test fuel drain. Either your tank is coming apart, or your fuel dealer has a lot of rust in his tanks. I guess the good news is the fuel looks clear and the particles are on the correct side of the first filter. There are a lot of people that had never changed the big filter, let alone drained a sample until the engine started running funny.
I doubt he has rusting in his tank or too much from the filler. Most of the pick-ups have plastic tanks, but not all. I would bet the particles are from where he gets his fuel.
___________________ Old Post from 2007: Here is the broadcast message about the liner separation, no actually TSB number given... Lack of Power, Trucks with Steel Tanks: Some trucks may have a lack of power due to low fuel pressure from a plugged fuel filter or in-tank pickup tube, or restricted fuel lines. This could be caused by the steel tank lining becoming de-laminated/flaking off. If this occurs, the tank will need to be replaced, along with the plugged components. Be aware that using biodiesel with more than 5% concentration (B5) may cause this to happen. The replacement tanks do have a more resistant coating to help prevent this occurance, however Ford still recommends using no higher than B5 biodiesel. Broadcast Message 6865, 7103. __________________ Eric Last edited by twoicebergs; 12-28-2012 at 04:57 PM. Reason: old post |
I looked at the tank today and I wanna say it was plastic...
So I got to thinking about this rust issue today. The station I get my fuel from is only roughly a year old and is the most active station in town (only 4 stations in town with diesel not hard to be #1...) so bad fuel should not be the stations fault. But who knows were the fuel comes from originally.
And I reeeeeeley want a extra fuel tank in the bed. So were and how do I install a aftermarket fuel/water/trash sep? Between the extra tank and main tank? After main tank and before factory filter?? |
You really need to go on-line to see what is offered. Then, you have to decide how you want it to work. Do you want a solenoid style in-cab control? Gravity to the main tank, or tied into the feed line? All the choices will affect ease of install, ease of use and cost.
For example: http://www.thefuelbox.com/Home.aspx Last edited by twoicebergs; 12-29-2012 at 10:16 PM. Reason: link |
