2004 6.0 sudden missfire and stall - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-26-2012, 08:43 PM Thread Starter
just bought this 04 f250 eclb. this is my third powerstroke but first 6 liter. a few days after i brought it home it started to develop an intermittent missfire. on 2 or 3 cylinders but would come and go never effecting the driveability. changed the oil and fuel filters soon after i bought it. but christmas eve i was driving and suddenly it seems to have lost maybe all but 2 or 3 injectors, the truck would barely idle and did not have enough power to even make it move. i have no idea what to look for. i thought it was little odd for that many injectors would fail at once. ive tested ficm voltage. came back with 48v and 47.5 under cranking. also after pulling the ficm its dated 2009 underneath. also tried unplugging icp sensor and did not seem to affect the running at all. the engine is dated 2004 and also has the icp on the valve cover so im guessing its a later 04. any help or thoughts would be very appreciated
1994 f250 powerstroke extended cab long bed
186,000 miles
5 speed manual 4x4
3 inch downpipe, 4 inch mbrp straight pipe
Diy intake
Glowshift gauges
ts 6 pos chip
fpr shim
work in progress
kgeezy is offline
post #2 of 6 Old 12-26-2012, 09:04 PM Thread Starter
also makes no difference hot or cold
186,000 miles
5 speed manual 4x4
Diy intake
Glowshift gauges
ts 6 pos chip
fpr shim
work in progress
kgeezy is offline
post #3 of 6 Old 12-26-2012, 09:57 PM
Powerstroke Techie
Quoted: 382 Post(s)
could be a stuck egr valve, among other possibilities. check for codes. first and foremost
the richest ones are not those who have the most, but those who need the least
**i don't use capitals. deal with it**
kaya is offline
post #4 of 6 Old 12-27-2012, 03:24 PM Thread Starter
well i have an egr delete im going to put on tonight. then ill reasemble and start testing fuel pressure and for any combustion gasses in the secondary filter housing?
186,000 miles
5 speed manual 4x4
Diy intake
Glowshift gauges
ts 6 pos chip
fpr shim
work in progress
kgeezy is offline
post #5 of 6 Old 12-27-2012, 07:57 PM
Powerstroke Techie
Quoted: 382 Post(s)
if you're just going to shotgun, pull the valve out first. look to see that there isn't any carbon keeping the valve from closing fully on it's seat
kaya is offline
post #6 of 6 Old 12-30-2012, 05:23 PM Thread Starter
did replace both fuel filters the day before this all started happening. but drove 100 miles or so after changing the filters with out problems. but i pulled the cap off of the secondary housing and when i cycle the key i get bubbles in the bowl. so possibly a leak at the primary filter?
186,000 miles
5 speed manual 4x4
Diy intake
Glowshift gauges
ts 6 pos chip
fpr shim
work in progress
kgeezy is offline
