Oil in Coolant - wrookie wrencher
Merry christmas to me, took my dog to the emergency vet to be put down yesterday after he went down hill quickly overnight. Was rewarded with this on the way home!
I'm dangerous enough with a set of wrenches to have done my own egr delete but am essentially an amateur, that took me about 14 hours. So my diagnosis is a blown oil cooler, I intend to do the work myself over the next week. I could use some help on what exactly to do and in what order. For example I've read about people starting to flush prior to replacing the cooler to attempt to get some of the milkshake out first. Do I do that? Could you folks give me a hand. Right now all i know is to replace the cooler and flush flush flush flush until the gunk is gone. did talk to some folks and they recommended to wait until the goo is gone to replace the hoses ect, seemed mostly driven by reducing the mess. Anything else I should be doing while I'm in there? Tomorrow I intend to drain the oil and verify there is no coolant present which could indicate some different problems. Maybe do some of the teardown weather permitting but it is supposed to suck bigtime here. With 8" and 37's it wont go in my garage either so it will be a driveway job in the cold. I intend to replace with an oem cooler, would love to upgrade to bulletproof but with the unknowns ahead of me dont want to spend that $ if I could be needing head gaskets. |
Sorry to here about your dog.
You most likely wont have coolant in the oil the oil pressure is higher than the pressure in the coolant system You can use simple green to flush out the oil in the radiator and engine. Last edited by Paintingman; 12-26-2012 at 12:20 PM. |
Truly sorry to hear about your dog. Having to deal with your truck on top of that is a slap in the face.
Things are always a bit dicey when the oil cooler ruptures. If it hadn't ruptured (just clogged), the guidance would be to flush the crap out of it before replacing the oil cooler. However, once the cooler has ruptured, you need to keep more oil from being introduced to the cooling system so your flushes are effective. But flushing AFTER the oil cooler has been replaced increases the chances of clogging the new oil cooler. I've heard of people in your situation flushing both before and after the oil cooler is replaced with some success. I'm sure someone with more first hand experience will chime in with better guidance. |
thanks so far guys! appreciate the comments on the pooch too...
to the top
Sorry to hear about your dog and looks like you've got the milkshake from a blown oil cooler. You'll need to clean out the both the oil and coolant passages. While running, the oil pressure is higher than the coolant pressure, but once the engine is off, the pressures equalize and that can allow the milkshake into the oil passages. Simple Green or other natural degreaser is your friend.
Thanks guys, what is the mix on simple green to distilled? Can I also do a reverse flush once the cooler is replaced?
Yeah, and would be what I would do. I would run straight simple green to get all the gunk out of there and reverse flush it using the hose. Once it stops sudsing, switch to distilled.
did 4 flushes today before ripping into it tomorrow. went from pudding to dirty and sometimes very clean water. fingers crossed, good thing is I had all the top off about 3 years ago for egr delete.
had the same thing happen to mine. had it towed to the dealer. they stated that it was past the point of flushing and had to have an engine replacement. luckily for me it was under warranty, otherwise i would have been looking at about 15k for the engine swap.
the dealer told me that they disassemble the engine and steam clean everything. then, they sell them as remanufactured or as warranty swaps for cases like mine. |
