06 6.0 started and ran for 10 min then died,no start
Hi, to start it off I do not know a lot about 6.0s. Went out to start it at 3 below not plugged in. Figured I would try it and see if it could do it being the pickup is new to me. Pickup started good, spun over nice, started and sounded ok for being 3 below. Then it ran for 10 min and just died with no restart. Checked the fuel filters they have fuel and not gelled of frozen. Eventually got it in the heated shop and warmed up. Put the battery charger on it and had it plugged in, same sh!t no start but cranking fast. The glow plug light comes on the tach shows engine RPM. The gauge shows engine oil pressure. I have tried starting it 6 times over the course of the day and nothing I have codes P2290, P1000, and P0284. Cleared them and none came back when I tried to start it twice. Any help whatsoever is appreciated, I will continue to search in the mean time. I only have an Edge evolution to pull codes with, I have never tuned this pickup with it.
Bump please
can you get an ICP reading? it sounds like a bad ICP sensor to me, do you hve the ability to do a contribution test?
you need a device capable of viewing some PIDs. icp, ipr, ficm voltage.
is there smoke out the tailpipe while cranking? |
Ok, if the ICP sensor is bad and I unplug it, shouldnt it start ?
I may have to speak with my local auto repair shop and get him to hook it up to his fancy snap on scanner to see what is going on. No smoke whatsoever, it doesnt even try to start. |
What is everyone doing for a fuel pressure sender and/or gauge ?
Is there any smoke at all exiting the tail pipe while cranking over? If no I can almost guarantee you have a HPO leak. You need to get it hooked up to either a monitor that can tell you icp voltage, icp pressure actual and desired, ipr % actual and desired, FICM main and logic volts and FICM sync. Once you can give us data on those PID's than we can go from there, but at this time if you don't want to just throw parts and money at it and hope your right you need to do the above.
Zero smoke. I will have to swing by the local shop and have him hook up his scanner to see what is happening.
Ok heres the deal why the pickup wont start. It is not building High pressure oil pressure, so I am looking at either an HPOP or the SCT fitting. It already has the upgraded SCT fitting so I am starting to doubt that it is the fitting. Just changed the oil and put in 5-40 rotella and two bottles of Revx. So what is the best route to go for getting a pump, OEM or whats a good aftermarket choice ?
