Powersteering leak few questions - Ford Powerstroke Diesel Forum
Old 12-25-2012, 12:19 PM
Chapter Director
Ok guys went out to my truck this morning and found power steering fluid on the ground. Now I looked at it and was able to figure out where it's leaking from there is a line that comes from the master cyclinder down to a pully it looks like a 3/4 bolt with a square fitting on it if I can get a pick ill put one up its raining so yeah. I'm not sure if I can just disconnect the line at the master cyc then unscrew the square nut u can't fit a wrench around the bolt due to the cross member anyone ever seen this
Old 12-25-2012, 12:34 PM
Chapter Director
This is the line going down to the pully
Old 12-25-2012, 12:35 PM
Chapter Director
Same line but top view going into the master cyclinder
Old 12-25-2012, 12:36 PM
Chapter Director
Finally the leak its self
Old 12-25-2012, 01:40 PM
Chapter Director
Any clues anyone lol
Old 12-27-2012, 07:57 PM
Feedback Score: 3 reviews
There should be a white Teflon/plastic seal on that fitting. Good chance that it failed.
When you go to put the new seal on, let the seal sit in really hot water for a couple of minutes to soften it up so you can stretch it over the fitting.
Sent from my iPhone using AutoGuide.com App
