Paranoid of my 6.0l
Looking for opinions....I have a 05 cc, with 150,000 miles. I purchased the truck new and have only had the following mishaps...injector went out after first purchased, then couple yrs later the High pressure oil pump, then the FICM about a little over a year later. All in a 7yr span.I have had signs of things acting up between these mishaps and would take it to the dealer for repairs, they would most likely not find much of anything. I have even went to other dealers and get the same answer. I NEVER have gotten any "Check Engine Lights" or the "Wrench", to alert me of any troubles. I keep my oil and filters changed mo frequently than my local "Mcddonalds". ....With that being said, I drive this truck everyday for work. I only use to tow (ocasionally) a fifthwheel that weights aroung 14-16,000lbs. Is there a Gas burner that would haul this type weight? Should I keep this truck and hope it doesnt leave me stranded like it has twice? Is this a sign to get rid of it before it cost more than I could afford?and how is trade in values on Fords in this shape?....Thanks..
I wouldn't keep it and "hope." I'd keep it and monitor vitals and do all of the proper maintenance, which is more than oil/fuel.
And I bet a V10 Ford or something would pull that trailer, but you wouldn't be happy at all with it. |
Fortunately you have come to the right place for reassurance.......first every 6.0 owner should have a monitor......Write Up: Monitoring the 6.0L PSD.
After you get a monitor you can post your various numbers to find out the health of your truck. Unfortunately there are some inherent problems with the 6.0 that once address, one can enjoy their truck without worry. Read the stickies and come back with questions, we'll be happy to clear up. Getting a monitor and installing a coolant filter is first and foremost, the best thing you can do. I installed the xdp bypass filter, and have the edge cts monitor. Welcome to the org. Sent from my phone that somebody didn't help me get. |
I would say you have a 7yo truck with 150K mi on it. If you think about it, she’s only let you twice; that’s a pretty good record. If you have done all the things mentioned in the bulletproofing thread you have about 20K more until she starts nickel and dimming you. A new truck can leave you on the side of the road too, it just costs more each month. Get you a tool kit, some parts and know how, and keep your truck. Its an adventure!
The bad ficm was more than likely caused from your batteries needing replacement, my guess is you replaced them around the same time you had ficm work done ?
I am with southend, get gauges on the truck and see how the oil cooler and icp/ipr #s are doing to get a good picture of the engines health. Proper maintenance is key and you can get many more years out of the truck yet. One thing you may consider doing would be some preventative work on it now to eliminate the possibility of future repairs. For probably around $3000.00 you can give yourself peice of mind and eliminate the things that can go wrong with it. The truck should have some attention too by replacing fluids on: axles,transfer case, transmission, p/s pump, brake system, maybe $700.00. If you were to put on a new oil cooler and B/P egr cooler update to the stainless hpop screen, standpipes, dummy plugs,stc fitting and replace injector o-rings you would be in good shape the way I am looking at it. So a $3700.00 investment into a truck that would cost $60,000 to replace seems like a easy decision to me. Your oil cooler may be fine I don't know you can figure that out once you put gauges on it. But those other items are what can cause you problems and they can all be dealt with now so you know they won't be a problem in the future. Myself I would keep it, not having a big truck payment is like getting money from heaven. Last edited by mhatlen; 12-24-2012 at 04:34 PM. |
Yup I am with these fellas! I have 170,000 miles on mine and has not given me a lick of trouble- due to the fact i am on top of maintenance and have done all the updates/ repairs to ensure a good healthy motor. I will always have my truck unless i wreck it of course, and when the motor goes in it? I will replace it! Again much cheaper to replace the motor then to replace with a new truck, especially if your truck looks as good as new.
Thanks you guys....maybe I am just a little fustrated with the truck. It has been a great truck and I would hate to get rid of it, due to all the other changes I would have to make. I have thought of getting the Edge insight CTS about a year or so ago and put it off. I do not have any type monitors or gauges to help monitor my truck, I have been driving blind the past 7yrs...lol...I have looked around for the best price on the CTS and found one for 330.00 from midwest auto on amazon.com....thanks for the reassurance and help me change my mind. As, this is my "First" diesel that I have owned.
.....thanks, and Merry Christmas. I will post back in a week or so with results when I get my CTS installed in truck. |
