High pressure oil leak is possible.... dummy plug o rings or sct fitting.... check oil pressure when cranking....I'm pretty sure it needs 550 to 600psi to crank.....
Just an option Sent from my DROID RAZR using AutoGuide.Com Free App |
it's early 04. no plugs or stc.
in order for the ficm to sync, pcm needs to see 500psi or greater. and signal from the cam sensor. without ficm sync, there will be no smoke out the tailpipe. you know what? just for the hell of it, disconnect the icp and try firing it up. like i said though, i've never seen a bad icp/pigtail cause a no start. not to say it couldn't happen. your icp voltage does seem to be jumping all over while cranking. however, if it were a shorting icp, as i'm leaning to with unplugging it, you'd be throwing an icp circuit code. can you view icp in a pressure value as apposed to voltage? and ipr in duty cycle? you're very limited right now with the device you have to monitor with. something capable of viewing more PIDs would be in order. it sounds to me like the ficm is not syncing for whatever reason. you keep throwing a cam sensor code as well. typically thrown from cranking without starting, but could also be the wiring. that would cause no ficm sync as well. when you replaced the sensor, did you look at the wiring carefully? somewhat common for the cam sensor wiring to chafe or become damaged. it's down low, so there's a lot of oil in the area. basically, you need to see if the ficm is syncing and what your icp pressure and ipr duty cycle are at |
Unplugged icp on change. I just called a tow truck it's going to the dealer for the first time in my ownership. I'm not pleased....
i'm sorry to hear that. i'm certain we could have figured this, had our scope of diag tools been broader.
let us know what they say. thanks |
Exactly my electronic tools are limited as only a shop would have the right computer. I will update this post to let you guys know the issue. This has been an ongoing issue that got progressively worst over 2 month period.
Hey guys problem was rather simple but as I said never would have got it with the computer on it. It was rust and corrosion on the block buttered the sensors out enough that they would not read. I remember reading that once on the boards but never thought of in. The dealer *** raped me 620 bucks to diagnosis and clean the areas.
