Smoke Coming From The Dip Sick? - Ford Powerstroke Diesel Forum
Old 12-22-2012, 06:37 PM
I have a very sick 2003 6.0 there is smoke coming out of the dip stick checked oil and it wasnt low at all and ideas? I have some other issues but im working them out now. Blew my rear end out 4 days ago so while im waiting on parts and rebuilding the rear end i figured i better fix everything else while im at it.
Old 12-22-2012, 06:58 PM
Thats normally caused by blowby, cracked rings, worn rings, scared cylinder walls, hole in a piston. How many miles, oem air filter, ccv reroute, ever had an injector dump fuel?
Sent from my phone that somebody didn't help me get.
Old 12-22-2012, 06:59 PM
Illiana Chapter Director
Some smoke is normal. Is it just a little haze?
Old 12-22-2012, 07:09 PM
how does it run? any blue smoke out the tailpipe?
typically, excessive blowby is cause for engine removal
yes it is just a little haze only seems to do it when the motor has been ran for longer then an hour or so
Old 12-22-2012, 07:13 PM
Its rough right now i had two injectors go out, putting 8 new ones in, likes to cut out under WOT, it wont hold boost while crusing it always used to hold at least 5 pounds, take a little bit to really get going after you give it more then half throttle, Just cleaned my turbo 3 months ago, also i have oil in my intercooler pipes Its taking a down hill drop on me fast
Old 12-22-2012, 07:15 PM
No blue smoke but puffs a white cloud at start up and runs really rough until its warmed up no power what so ever
Old 12-22-2012, 07:16 PM
Oil in the intercooler tubes and boots is normal too. The CCV is routed back into the intake side of turbo and that's where the oil comes from. So far, you're not describing anything abnormal.
how do you know it's the injectors? does the rough running go away once warm?
Old 12-22-2012, 07:17 PM
That most likely is being caused by an FICM that has low voltage. Check the FICM while cranking the engine and see what the voltage drops to.
