intake bolt broke. - Ford Powerstroke Diesel Forum
Old 12-22-2012, 04:09 PM
intake bolt broke.
So im workin on changing an oil cooler, everything went smooth. until 1 intake bolt broke. its the next one up from the last one on passengers side in front of exhaust down pipe. will it cause a leak or a problem if i cant get the old one out and put a new one in. or can i get away without
Old 12-22-2012, 04:33 PM
Illiana Chapter Director
I'd say that once you pull the intake off, if you get a stud remover and put on it, it will probably come out. Just soak it with a good penetrating oil.
Old 12-22-2012, 04:38 PM
usually with the tension relieved, due to the head being busted off the bolt, the rest should even just spin out by hand. vice grips should do with ease. i doubt it's been cross threaded, since the tips of those bolts have a taper on them to guide through the gasket holes
