Stupid truck; what now?
So I just changed my oil, I go to turn on my ignition and the little air pump that sits over top the front right wheel in the engine compartment cycles on and doesn't turn off. I start the truck, run it around the hood, still running i turn it off check oil levels and then turn the ignition on again an that stupid little pump cycles on and will not shut off unless I un-plug it.
So what is this pump, what does it do, who wants to buy a truck.... ![]() I don't think it is my vacuum pump for my 4x4, i traced those lines back to another housing next to this pump????
It's the vacuum pump for your 4x4 and for your heater control valve. If it isn't turning off than you have a leak somewhere. Possibly the vacuum tank is cracked and leaking or the lines going to the 4x4 or the line is hanging off of the heater control valve.
Well a few years ago I disconnected the pump from the 4x4 and plugged it. Need new hub seals and vacuum line....
Interesting fact, two weeks ago I found some coolant under my truck. Not a significant loss and I have not been able to identify or recreate the leak. Think the two may be related. This lead me to the oil change... no coolant in oil. |
No, in no way can they be related. Look at your thermostat housing it's probably leaking
Sent from my iPhone using AutoGuide.com App |
Coolant loss, small amount but unidentified. Check all your connection points; sometimes they will leak under pressure. Of course, also check for minor puking.
They can in fact be related. The heater control valve has been known to leak and it is controlled by the vacuum from the vacuum pump.
But disconnecting the hubs from the vacuum system in no way affects the HCV.
I'm talking about his coolant leak along with his vacuum pump problem.
ok!! My money pit is at it again!!! blowing white smoke and loosing coolant!!! Head Gasket? or is it egr related?? Ran into a guy the other day that said it was egr and that I needed to put in the egr block-off kit??
