2004 6.0 Periodic No Start - Ford Powerstroke Diesel Forum
Old 12-20-2012, 03:56 PM
I have a 2004 F350 with the 6.0. I have had a few problems over the years (turbo vanes stuck causing over boost, faulty EGR and bad FICM). These items were all either repaired or replaced. No major problems in the past year or so.
Periodically (4 times in about 5 months), the truck refuses to start on its own. The voltages are good with no codes. The outside temp doesn't seem to be an issue and the problem has occurred with the engine cold or warm.
To get the truck started, I use a starter fluid (I know this isn't a good idea) and the engine fires right up. The truck runs fine with good power and the no start issue doesn't occur again sometimes for months. Again, the no start condition seems to be random, not affected by outside temps or with the engine hot or cold. The Ford dealership service department can't find the problem and a local diesel repair shop hasn't come up with a solution either.
Any thoughts, recommendations etc. would be greatly appreciated.
Thanks
Old 12-21-2012, 04:33 AM
any codes?
Old 12-21-2012, 06:44 AM
No codes at all
Old 12-21-2012, 06:49 AM
How are you pulling codes?
Sent from my phone that somebody didn't help me get.
Old 12-21-2012, 06:59 AM
Initially with a Banks PDA. Ford service department confirmed no codes with their equipment.
Old 12-21-2012, 07:40 PM
hmm. not even a can bus interruption code?
usually if no codes are thrown for an issue like this, i suspect the fuel system...usually
Old 12-21-2012, 08:01 PM
check connections on ficm next time this happens also feel the harness coming off of the ficm and make sure there is no chafing
