Loss of power Alot of black smoke
I have a 2006 F350. I have an egr delete, garret powermax factory replacement turbo, a power hungry edge cts gryphon tuner with an aggressive tune. My heads are studded with factory gaskets. A couple days ago when it reached some cooler temps here (25-35 degrees) I started noticing loss of power and lots black smoke until ot warmed up. The only items that havent been replaced are the hpop, and fuel injectors. As for everyone else i cant afford both at once where should I start?
Sent from my SAMSUNG-SGH-I897 using AutoGuide.Com Free App |
Load test your batteries and perform the ficm check procrdure.
Sent from my phone that somebody didn't help me get. |
Ficm is 47.5 during cranking and drops below that. Alternator just replaced with green machine. Batteries have been holding charge.
My apolagies. The ficm never drops below 47.5. I will have batteries tested today. Thanks
have you checked for codes?
Only showing p403 & p405 for my egr delete.
try returning to stock for starters
You could also try having the computer flashed, they are known for having a glitch that causes that too
