when i first step on the gas the truck seems to run on only the motor power and literally has no power. the turbo doesnt spool up untill after 30 seconds or more. i know the injectors are going but i have had this problem since i got the truck and before i replaced the turbo completely. if any one can help it would be much appreciated
If the injectors are going, it's for a reason. Are you running motorcraft or racor filters, have you checked the filters? Have you checked your fuel pressure, egr valve stuck open, do you have a monitor?
Sent from my phone that somebody didn't help me get. |
30 seconds???
Yea, lol, thats not turbo lag.
So it takes 30 seconds for the boost gauge on the dash to register?
Sent from my iPhone using AutoGuide.com Free App |
Its my dads truck and I can't stand to sit here and watch it get destroyed. I just put a new Turbo in with an egr delete about a year ago he has a bully dog chip on his **** and keeps it performance. When you put it in gear and press the gas it has a hesataion and the Turbo is not spooling up at the right time all filters should have been done 2 months ago
what year is the truck?
tried returning to stock? check the codes check for boost leaks exhaust leaks at the up pipes/manifolds check your ebp, map and maf readings check the ebp tube and harness |
