p006A - Ford Powerstroke Diesel Forum
post #1 of 8 Old 12-15-2012, 09:48 PM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
p006A
I have a 2004 f250 6.0(its a 2003 engine) I have blocked off the EGR cooler and I have a 4 inch magna flow turbo back exhaust. I do not have any custome tunes at this time. should i be concerned that this code came up tonight while driving also the 0401 code came up but ii think that is just saying the egr valve isnt getting flow. what should i do? is this just the same crap from me blocking off the egr?
jmeaby is offline
post #2 of 8 Old 12-16-2012, 05:39 AM
Heathrm's Avatar
The P0401 is standard because of your EGR block-off. The P0006A I believe only gets thrown if you have the inferred EBP calibration. I didn't get that code until I got the PCM flashed. I have both codes and have no problems with the truck. I don't worry about either one.
2004 Excursion Limited, 198,000 miles,
Edge CTS (Gauges only), ZooDad, Turbo Timer, DieselSite Coolant Filter,
RCD EGR delete, CCV reroute, Amsoil By-pass Filter, FireStone RideRite Air Springs,
FICM from Ed with Atlas 40 tune, No Kitty, FPR Blue Spring, DC XP270 Alternator
Heathrm is offline
post #3 of 8 Old 12-16-2012, 07:39 PM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
do you know what the oo6a means though
jmeaby is offline
post #4 of 8 Old 12-16-2012, 07:49 PM
p006A Map Mass air flow correlation bank 1 A Ford specific code not in the standard DTC databases.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #5 of 8 Old 12-17-2012, 01:39 AM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
But hear is the question what causes thus to come up in the first place and should I be concerned?
jmeaby is offline
post #6 of 8 Old 12-17-2012, 04:22 AM
Well now that is not a simple question to answer.
First off before you get too concerned you need to clear the code with a scanner and retest the truck. Take it for a nice long drive and see if the code pops back up. It may have been a momentary fault. If it repeatedly occures then ya need to find out why.
Essentially at some point while the pcm polled its sensors MAP and Maff values
did not agree or balance for the particular operateing conditions of the engine
at the time the poll was taken by the pcm.
This may be a pcm hiccup because that type code is useually seen in a gas engine if I rember correctly.
post #7 of 8 Old 12-17-2012, 05:51 AM
Powerstroke Techie
Quoted: 306 Post(s)
you've got the early 04. almost certainly has the inferred ebp pcm reflash. the p006a code is often a result of this reflash. with the egr blocked, it probably set the code, since egr also doubles as the turbo wastegate, to an extent. the reflash omits the actual ebp reading and instead, calculates the reading through map and maf. to achieve this, the map sensor readings are now hyper-sensitive. so the map/maf correlation code gets thrown out much more often with the reflash.
i would look for any exhaust leaks. especially around the manifolds, turbo up pipe bellows, and turbo flange. look for soot around the firewall. that is the most common cause of this code on late trucks (late 04 and up), that don't run inf. ebp.
or, if you have an aftermarket air cleaner unit, that can sometimes trip the code as well.
basically, if you don't have any exhaust leaks, i wouldn't worry about this code
the richest ones are not those who have the most, but those who need the least
kaya is offline
post #8 of 8 Old 12-17-2012, 04:13 PM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
Well the truck started throwing a few codes now ill get all the numbers in here later tonight.(I'm currently at work) but it threw something about throttle position and fuel reading not sure what they all mean yet but ill be searching later. If I got the custom tunes done that I'm gonna get from innovative diesel would that turn most codes off since the egr is disabled?
jmeaby is offline
