6.0 no crank - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-14-2012, 12:11 PM Thread Starter
blowinsmoke4life's Avatar
Quoted: 2 Post(s)
Garage
Send a message via AIM to blowinsmoke4life
6.0 no crank
For about a month the truck would crank and not crank real sporadically. Finally I noticed the post for the ignition wire was lose and replaced the solenoid only started up fine again for 4days. last night it didnt crank again, rolled started it and fired right up. Put new starter in no crank at all. Mind you everything else operates correctly injections buzz and all that at on position but nothing at start position. So i checked to see if power was getting to the starter when the key was turned to start and it showed no voltage. All fuses under the dash look ok, any suggestions? Thanks in advance, Ryan
1999 F250 CC SB 4x4 4r100 ts chip w/ php tunes
1989 F350 CC LB 4X4 N/A 7.3l IDI zf5 swapped and rebuilt engine. sold
blowinsmoke4life is offline
post #2 of 5 Old 12-14-2012, 12:34 PM
crspeedy67's Avatar
Check to see if you have voltage out of your key switch in the start position.
Chris
2003 F350 DRW
New 6.0 Jasper engine with studs
Edge CTS
SCT 3015
Cat ELC
Sinister Coolant Filter
4in Magnaflow turbo back (no cat)
High Idle Mod
100gal aux. fuel tank (electric pump)
crspeedy67 is offline
post #3 of 5 Old 12-14-2012, 12:38 PM Thread Starter
Quoted: 2 Post(s)
Garage
Where can I check voltage at the ignition switch
post #4 of 5 Old 12-14-2012, 12:43 PM
crspeedy67's Avatar
the harness should come out near the bottom of the steering callum you will have to look up wiring diagram to find the right wire
Chris
2003 F350 DRW
Edge CTS
SCT 3015
Cat ELC
High Idle Mod
post #5 of 5 Old 12-14-2012, 12:56 PM Thread Starter
Quoted: 2 Post(s)
Garage
Ok thanks ill check that
