Hot Shots Secrets Oil and Fuel Additives it works - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-13-2012, 10:30 PM Thread Starter
Power$troke's Avatar
Quoted: 2 Post(s)
Garage
I've been having some rough starts/ excelleration till the temps get up to 120almost like its misfiring kinda? So I was reading about the Injectors having oil pressure issues ect, So I found the Hot Shot Secrets oil / fuel products and after alittle research found out that International actually looked to them to help resolve there injector issues due to buildup from oil. So to get to the good part....
I have 135k on my 6.0 and have already replaced one injector (#5) at 128K and after that it ran perfect till now. So I added the oil and fuel treatments per instructions and with in 80 miles I have noticed a huge difference in starting and excelleration when temps are well below 120 like at 91degrees alot less of the misfire/hesitation feeling. I have read that many others reported notices around 100 miles and up also. I hope the improvements continue to get better. I would say if your having issues that seem like they may be injector related try Hot Shots products 60.00 bucks versus 1500.00 or more for injectors well worth the 60.00 bucks to try.
Let me know if any of you have had any similiar luck or difference of opinion on this or similiar products.
2006 6.0 SD Crew Cab Lariat "Bullet Proofed"
8 inch Kit
Dual Steering Stabilizers
Adjustable Trac bar
37" Trail Grapplers
20X12 Armour Rims
ARP Studs
SCT X3
XDP EGR Delete
Edge Evolution
BPD FICM
PM Coolant filter
MBRP 4in Exhaust
Blue Spring Mod
High Idle Mod
HID 6k headlights / 23" LED Light bar 9000 lumens
Rock LED Lights in each fender well
Oracle LED wheel Rings (White LEDS Only)
LED BED Lights
Horn Blaster Horns
200psi 13 gallon on board Air system
Power$troke is offline
post #2 of 4 Old 12-14-2012, 12:04 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
I've used it and it helped for about 1000 miles. Then it was all back and it also caused a hpo leak in my truck and caused a no start (I don't think it actually CAUSED the leak, but rather made the leak worse causing the no start condition).
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 4 Old 12-14-2012, 12:58 AM Thread Starter
Quoted: 2 Post(s)
Garage
Do you recall the location of the leak? So do you believe that it thins the oil maybe?
8 inch Kit
Adjustable Trac bar
37" Trail Grapplers
20X12 Armour Rims
ARP Studs
SCT X3
XDP EGR Delete
Edge Evolution
BPD FICM
PM Coolant filter
MBRP 4in Exhaust
Blue Spring Mod
High Idle Mod
LED BED Lights
Horn Blaster Horns
post #4 of 4 Old 12-14-2012, 01:04 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Either thins the oil or cleans all of the sludge lol take your pick. I ended up replacing everything in my hpo system minus the icp sensor, hpo rails and the branch tubes. Everything else was leaking and needed replaced.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
