Need help ASAP: No start - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-11-2012, 10:33 PM Thread Starter
ZCMiller's Avatar
Just got a Livewire TS from Vivian and loaded the tunes from her on the unit and proceeded to the truck to transfer it over. I'm new at the process but just watched the screen for directions. Everything seemed to load good. I wasnt thinking and left the lights on during the upload and some other tinkering. When I went to start the truck it would not turn over it just flashed all dash lights and went dark. I shut the key off and tried again and same result. I then checked the voltage on the TS and it was reading 8-9 so I got the tractor out to just it and charge the batteries. The batteries are year old everstarts in the truck when I bought it. Theyre only rated at 650 CCA @0* so I dont think they are really addequate for a diesel around here. I had been having to crank a few more seconds on cold mornings than what I felt was appropriate before this all happened so I was in the process of buying new batteries. Well I never could get the voltage to increase while jumping the batteries. My cables seem fine. I did not start the truck since Monday at about Midnight and this all happened about 24 hours later. Im worried I fried something messing with the tuner, but then I am hoping the batteries were just bad and between letting it sit for a full day in 30* weather and then letting it sit with high beams on for 15 minutes is the reason it wont crank or even take charge. Any help or suggestions would be appreciated. Thanks
'96 F-250XLT 4x4 Regular Cab
ZCMiller is offline
post #2 of 6 Old 12-12-2012, 06:45 AM
Baseically your not going anywhere for a while
Now I can't say for certain on the tuner but every electrical/electronic device has a low voltage threshold. It can't have done it anygood but maybe no real harm.
As far as booster cables unless you want to let it run allday with a brick on the pedal and pretend it's a trickle charger, your not gonna build up enough volts/amps to get it to start. Not with that low a charge and at those temps.
8vlt and below the PCM and FICM will not work so the injectors can't fire. The glow plugs wont work, the fuelpump isn't turning as fast as it should etc etc. Never mind being able to roll the engine over fast enough to generate enough compression to ignite the fuel/air mix.
Pull both batteries and charge them overnight a full charge or replace with good hot batteries.
Good luck.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 6 Old 12-12-2012, 06:48 AM
jermcd's Avatar
Plug the truck in assuming it has a plug? not sure if all of them that yr do or not and take the batteries out and get them load tested. If there is any question good or bad, replace them. Load testing will also bring them to full charge if they are good and she should fire right up if thats your issue.
currently driving a 335i bmw, no more powerstoke
Previous powerstrokes-
2002- F250 XL 7.3 auto, 4x4
2001- F250 Lariat 7.3 auto, 4x4
2002- F350 Lariat 7.3 Dually, auto, 4x4. 141k miles
jermcd is offline
post #4 of 6 Old 12-12-2012, 06:51 AM
kendallcschm's Avatar
Send a message via Skype™ to kendallcschm
i would get new batteries.. 650 is nothing in a cold area.. mine are rated 800 CCA
2007 Ford F250 Lariat 6.0 Powerstroke
mods:
Banks Ram air
Sinister Coolant Filter
Swamps 48V FICM with PHP Atlas 40
B&W turnover ball hitch
EGR Delete
Diesel Site Intercooler Boots
SCT livewire TS 5015 w/IDP custom tunes
Agressive street, Tow W/jake brake, Economy
Other rides:
2010 Ford Explorer 4.6 24V V8
1999 Ford Mustang Cobra 4.6 32V V8
Mods:
JLT True CAI
Smoked Heads/tails
kendallcschm is offline
post #5 of 6 Old 12-12-2012, 07:02 AM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
Everstart more like neverstart. Horrible batteries. The glow plugs are pulling about 300 amps, so you probably don't have enough current to crank and run glow plugs. Just my 2 cents. Put 2 new batteries in.
Sent from my PG06100 using AutoGuide.Com Free App
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #6 of 6 Old 12-12-2012, 09:29 PM Thread Starter
ZCMiller's Avatar
Finally got it jumped. Had to use the tractor battery for one side and jump straight from tractor to other side under hood. Then put everything back where it went and drove for awhile. All has been good. In the market for some heavier batteries. Thanks for the help.
ZCMiller is offline
