6.0 chugging - Ford Powerstroke Diesel Forum
post #1 of 26 Old 12-11-2012, 08:23 AM Thread Starter
6.0 chugging
my 6.0 just started chugging when starting up an incline,or just excelerating, kinda jerks like it wants to run out of fuel. i changed the fuel filters and cleaned the EGR valve to see if that would help but NO. any ideas???
Mus**06 is offline
post #2 of 26 Old 12-11-2012, 08:24 AM
Do you have a fuel pressure gauge?
Moto2four is offline
post #3 of 26 Old 12-11-2012, 08:37 AM Thread Starter
no Fuel pressure gauge.
Mus**06 is offline
post #4 of 26 Old 12-11-2012, 08:41 AM
Without gauges and a monitor, troubleshooting issues on these trucks is very difficult. Is say check ficm voltage and fuel pressure. Have you ever cleaned the turbo vanes? Is the truck stock? The factory spring in the fuel pressure regulator can get weak over time.
post #5 of 26 Old 12-11-2012, 08:50 AM Thread Starter
Stock truck, had the injectors check their all good, had the FICM checked it was at 48 volts. had never clean the turbo, it has 150,000 miles right now.
Mus**06 is offline
post #6 of 26 Old 12-11-2012, 08:56 AM
The turbo vanes *could* be stuck. Its not hard to remove and clean the turbo. If you do a few searches on here and look around on YouTube, you will find some good tips and write-ups on cleaning it yourself. A egt guage would help confirm turbo vane issue.
post #7 of 26 Old 12-11-2012, 08:57 AM
My 6OH Hates Me
mudrunninpig's Avatar
Quoted: 24 Post(s)
Where do you live? Is it just at start up. Does it run ok when warm?
Mike
"The Iron Pig"
mudrunninpig is offline
post #8 of 26 Old 12-11-2012, 09:35 AM Thread Starter
runs bad when cold then gets alittle better when warm..Atlanta
Mus**06 is offline
post #9 of 26 Old 12-11-2012, 09:40 AM
kendallcschm's Avatar
Send a message via Skype™ to kendallcschm
my 6.0 just started chugging when starting up an incline,or just accelerating, kinda jerks like it wants to run out of fuel. i changed the fuel filters and cleaned the EGR valve to see if that would help but NO. any ideas???
this isn't a problem.. its called the choo choo train mod in which the truck gains infinite HP and torque.. JK... is the check engine light on and do you have a code reader set from autoingenuity or something?
2007 Ford F250 Lariat 6.0 Powerstroke
mods:
Banks Ram air
Sinister Coolant Filter
Swamps 48V FICM with PHP Atlas 40
B&W turnover ball hitch
EGR Delete
Diesel Site Intercooler Boots
SCT livewire TS 5015 w/IDP custom tunes
Agressive street, Tow W/jake brake, Economy
Other rides:
2010 Ford Explorer 4.6 24V V8
1999 Ford Mustang Cobra 4.6 32V V8
Mods:
JLT True CAI
Smoked Heads/tails
kendallcschm is offline
post #10 of 26 Old 12-11-2012, 10:00 AM Thread Starter
no check engine light, but the water in fuel keeps coming on. i change my filters regurlarly and drain the fuel pump off. it will go off for a while then come back. also keep additive in it to try to keep water out.
Mus**06 is offline
