04 6.0 no power - Ford Powerstroke Diesel Forum
Old 12-09-2012, 06:45 AM
04 6.0 no power
I have a 04 6.0 6 speed. and my buddy has a 02 7.3 6 speed and his truck has ten
times the power my truck has. On take off and throttle responces my truck want move out it own way compaired to his whats up?????
Old 12-09-2012, 07:03 AM
You need a monitor, otherwise we're guessing.........Write Up: Monitoring the 6.0L PSD.
I'll guess turbo sticking to start with.
Sent from my phone that somebody didn't help me get.
Old 12-09-2012, 10:55 AM
No way a 7.3 should compare to a 6.0 stock for stock. How many miles on it? How long have you owned it? You have the routine maintenance (fuel and oil filters) done on it regularly? And ditto on above, any monitors at all?
Old 12-09-2012, 02:18 PM
My truck has 70,000 miles and his 145,000. And all maintenance up to date. My truck
Is like drivin a 4 cyclinder Toyota to a to a v8 f150. My truck runs good and I get about 18
Mpg but not much power. It does have a little miss once an a while but only when fuel gets to 1/2 a tank or lower but above that it runs fine. Just has no power very SLUGGISH all around.
Old 12-09-2012, 04:24 PM
How long has it been this way? How long have you owned it? Any smoke out of t pipe?
Old 12-10-2012, 03:10 AM
No smoke and 3 years. Thought it was just truck until I drove his 7.3. I had the ficm replaced about 2 years ago but still the same just wouldnt start when cold.
Old 12-10-2012, 04:34 PM
No tuner on his truck I assume? Otherwise comparison wouldn't be the same. Can you tell if the turbo is spooling up or not?
Old 12-11-2012, 06:46 AM
No tuner both trucks stock. yes the turbo is spooling.
Old 12-11-2012, 07:18 AM
Have you changed the fuel filters? Could you be gelling?
Old 12-11-2012, 07:39 AM
Send a message via Skype™ to kendallcschm
maybe your not getting enough fuel... fuel pump?
