another ficm question - Ford Powerstroke Diesel Forum
post #1 of 11 Old 12-08-2012, 03:47 PM Thread Starter
i have read a ton on these things and still not sure about one thing. I have an 07 6.0 with low voltage on the ficm. Batteries are good. I came across a ficm from a friend that just got it back from being rebuilt but his truck is an 05. My question is can i put it right in my truck or should i just switch out the power supply side?
speedymike136 is offline
post #2 of 11 Old 12-08-2012, 04:36 PM
southend's Avatar
You should send yours to ficmrepair.com, and be done with it.
Sent from my phone that somebody didn't help me get.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #3 of 11 Old 12-08-2012, 04:54 PM Thread Starter
That's what I wanted to do but I need the truck for work. I was hoping this other ficm would get me by
post #4 of 11 Old 12-08-2012, 04:55 PM
southend's Avatar
I believe it should work fine.
southend is offline
post #5 of 11 Old 12-08-2012, 05:21 PM
I have a 7 pin ficm that has been repaired by Ed @ ficmrepair.com and loaded with the atlas 80 that i will sell you. It is a brand new 7 pin and Ed upgraded it with his 3 year warranty mods and put the Atlas 80 on it. It was bought in May of 2012. It will work with any 6.0 because it has been programmed. PM me if interested. $300 shipped.
Sent from my DROID RAZR using AutoGuide App
2012 F250 Lariat CCSB FX4, Gooseneck and 5th wheel prep package, H&S Minimaxx, 5" AFE SS straight pipe, EGR delete with factory EGT sensor, 35" Toyo MT's on stock rims, and Bilstein 5160 shocks.
thomaslord84 is offline
post #6 of 11 Old 12-08-2012, 05:22 PM
Forgot to mention that if you tow heavy (10k+) then my ficm is not for you.
post #7 of 11 Old 12-08-2012, 05:29 PM
southend's Avatar
Thats a heck of a deal.
southend is offline
post #8 of 11 Old 12-09-2012, 07:57 AM Thread Starter
There seems to be another problem. I swapped out the ficm and it read 0 volts so I switched back to my old one and now I have 0 volts on that one also. I would have to imagine there is something wrong with the wiring harness but how can I check that.
post #9 of 11 Old 12-09-2012, 01:58 PM
Yea I'm selling everything on my truck for approximately 1/2 of what i paid for the parts. I figure that the stuff is used and I'm not trying to screw anyone over.
post #10 of 11 Old 12-12-2012, 06:34 AM
FICM Replacement
I got mine from Northern Auto Parts in Iowa. Like $350. They have rebuilts on the shelves. Order online or by phone which is quicker. They give you your core deposit back when they receive it through the mail.
The job took me a little over an hour. Sent the core back in the same box.
djbinding is offline
