Odd turbo noise. Vid inside. - Ford Powerstroke Diesel Forum
Old 12-06-2012, 03:31 PM
Had a the truck in at the dealer the other week for an HPOP repair and i got it back and the turbo now makes an odd noise between gear shifts and when i use the motor to slow down(leave it in gear and just let off the throttle)
The truck seems to run out fine but the noise makes me nervous
Here is a vid of the truck.. you can hear the noise at the 8-10 sec mark and the 23-27sec mark. sounds like the turbo is wining down or a bearing noise..
Old 12-06-2012, 04:24 PM
No video link.
Sent from my phone that somebody didn't help me get.
Old 12-06-2012, 04:56 PM
I really don't know that much to give ya a diagnosis. Have you checked your intake and make sure it seated properly? My mechanic found something had gone thru my turbo and it was making a similar noise. My filter was Afroengineered with a stock housing and a car air filter. So it was f-Ed when I got it.
Sent from my iPhone using AutoGuide.com App
Old 12-08-2012, 09:13 AM
if you're talking about the droaning noise, i wouldn't worry about that. it's normal on some of these turbos. did the dealer service the turbo or open it up?
Old 12-08-2012, 12:52 PM
Actually there is a tsb for certain year 03 turbo droan, and an update to the bracket.
Old 12-08-2012, 06:14 PM
hmm. i'll have to check that out. thanks for the heads up
Old 12-08-2012, 06:20 PM
Tsb 04-18-4, it actually says built after 09-04.
Old 12-09-2012, 03:53 PM
Yes it's the droan or whine when the turbo comes down. I thought that maybe it was a gear whine from the trans but I makes the same noise if you free free the truck with the clutch in or the clutch out.
If you guys think its fine. I'll be happy. I pulled the intake. All looks good shaft play is hardly any.
Am I just being super paranoid to a new sound??????
Old 12-09-2012, 04:26 PM
Check your turbo mounting bolts, and lookup the tsb I listed, it may apply to you.
Old 12-09-2012, 04:38 PM
My truck is a may 03 truck. But I'll look into the tsb. I'll check the bolts tomorrow after I wake up. I'm headed into work here soon. Sound does not seem to be getting worse either
Edit I tech did not clean the turbo when it was in for the hpop repair
