new head gasket on drivers side now no oil pressure at idle..
has anyone experienced this? i just replaced the head gasket and 3 bent valves on my drivers side head and now when it starts at idle it has no oil pressure and once you rev it above 1000 rpm it is completely normal.. what is going on? i have read it could be the ball bearing in the HPOP but what are the odds it just "FELL" out while i was working on the head? it was perfectly fine before this.. but right before i pulled it apart it was hard to start when cold.. but only did it 2 times before i pulled it apart.. truck is a late 04 f250 4x4 with only EGR delete and cat removed.. no tune or monitors....
You should pull the regulator on the front cover for the lpop, and inspect it. You may need to inspect the lpop too.
Sent from my phone that somebody didn't help me get. |
How do i find and or check those? is that where i pull the oil filter off and see if it fills quickly? and do you think me having he oil filter housing off while i did the head gasket could have anything to do with it?
![]() Pulling the oil filter and cranking over will give you somewhat of an indication of oil pump operation. Having the oil housing off has nothing to do with lpop failure, the oil pump is located behind the balancer. It's best if you hook a guage up to it to see how much lpo p pressure you have. How do you know your oil pressure is low? The sensor for the idiot guage only lets you know there is at least 7 psi. Sent from my phone that somebody didn't help me get. |
thats all im going by is the idiot gauge... it has never done anything like this before i replaced my head gasket other than b hard to start.. so anyway i pull out that plug then what?
ok so i will check my sensor and that spring and see what i find ... possibly wont report back till friday though.. thanks for the input so far
Welcome, dont forget to update.
yup thanks again
I tried to get that plug out today but i don't have a Allen head that big... So i will try to get 1 tomorrow and report
