6.0 random acceleration bog - Ford Powerstroke Diesel Forum
Old 12-01-2012, 05:23 AM
Hello! Have been searching these forums and the Internet for a answer, but can't seem to find a duplicate situation. There was a post by Polliewog with a similar issue.
First, this has been happening for over a year. Sometimes it does not do it for a week and sometimes it does it 3 times in one trip. Will be driving along, slow down for a corner and the foot feed is dead. No power. Only cure seems to be putting our foot to the floor and the truck slowly starts to accel with a huge cloud of white/gray smoke. May run fine after the next stop and go, may not. Totally random. Usually happens one every trip to town, but like I said before, not always. Tried power service additive with no change. Dealer cannot find a cause.
Second issues is slow cranking to start. About 3 months ago alternator died causing truck to idle only, would not go and would not start after shutting down. Towed to dealer, replaced alt and now it cranks slow and takes a bit of cranking to start. Could this be batteries? Will a load test tell anything? If one bad should we replace both? They are Interstates 1 year old.
Finally truck sat outside for a week and tried to start in about 10 degrees F. Slow crank no fire. Got a boost from a wrecker, little bit faster crank no fire. They towed it in, left it in shop overnight, charged batts and then it started. Still a bit slower crank than normal.
Thanks for any advice you can give .
Chris
Old 12-01-2012, 05:32 AM
Send a message via Skype™ to kendallcschm
Chris
this is a 6.0 right? if the batteries are weak or dieing they can take the FICM with it... check the FICM voltage cause my truck was like that.. my batteries were weak and took my FICM with them, weak bats cause the slow crank, ficm caused the accel problems.. infact at one point i could floor it and not get over 30 MPH.. your getting boost right?
Old 12-01-2012, 06:25 AM
Thanks for the response!
Yes...getting boost. When it eventually works itself out of the bog it pulls like crazy. Yes, this is a 2005 6.0.
Like I said before, this bog is random...
Old 12-03-2012, 09:35 AM
Did some more research today, and found the EGR valve totally plugged. Cleaned and going to reinstall. Also found a battery was bad. Totally dead. Getting that replaced today also.
egr valve.jpg - 2005 Ford F-250
