Cold start knock possibly?
Hey everyone. i own a 2003 f250 6.0. when i start it cold outside, it almost sounds like it has a knock to it for a while, when it warms up it stops and runs pretty good. is the knock normal on a cold start? i run synthetic 15-40 amsoil in the truck, and i go about 6000 miles on a change, is that to much even with synthetic? thanks
my 2006 6.0 does the same when it is cold. Dont worry about it. Plug it in when ot gets below 40 and that will help alot. Knock for a diesel is not bad just dont drive it for at least 5 minutes so it can warm up a little. It is also recomended to go to a lower weight in the colder temps. hope that helps
thanks for the reply man. i never plug the truck in, and i always start it at cold temps lately. its always colder than 40 in the mornings here. sometimes below zero.
wow below zero is even worse. Yeah always plug it in below 40 for sure below 30. Will help save ur injectors,glow plugs, and is a whole lot easier on ur engine. Just remember to unplug before you start it or u run the risk of shorting out the block heater. Let me know if plugging it in helps it!
i started mine once when it was 20 below and the block heater was NOT plugged in...at the time i had a plug in the exhaust manifold where i had pulled my thermocouple...when it started it RATTLED and SHOOK so hard i thought the whole truck was gonna come apart..the damn EM plug shot out right when it started and i heard the exhaust leak...it sounded like crushed ice in a metal blender...I FREAKED!!!
![]() as soon as i started driving i knew what it was.. i went back to where this happened after all the snow melted...that was 4 moths later, and i found that stupid little plug....it was still there... i have a big ol' hose clamp wrapped around the one i have in now.. 6.0's don't like cold oil!! |
