2005 6.0 fan shroud importance.....
got mad with the shroud while replacing water pump. clips broke off and removed entire shroud. how important is it for these engines as far as funneling air to radiator? thanks!
Just about the most important thing there is on the cooling system. Without it you will not get enough airflow to and thru the radiator, next to nothing heat exchange for the coolant. The clutch fan is now about useless.
Ya had just as well as shot it between the eyes. |
Important on every motor under normal use. Even my briggs and stratton tiller motor.
Sent from my phone that somebody didn't help me get. |
ok I figured it was needed .. already got another on the way. got another bigger issue in that my egr valve is wet and losing coolant rapidly. want to fix prob before it gets to head gaskets. I assume a egr delete is in order. any advice?
what is best of bottom line units that I can do on my own?
so a oil cooler is automatic if you delete egr?
Yes sir, thats the reason the egr cooler fails, lack of coolant due to clogged oil cooler. That is why a monitor and coolant filter are absolutely necessary also.
is a tuner 100% necessary? thinking bout the sct x3. also can I just drive a freeze plug in the end of the pipe and shut off exhaust flow?
