degas bottle puking - Ford Powerstroke Diesel Forum
post #1 of 30 Old 11-26-2012, 07:43 AM Thread Starter
gdcoker's Avatar
Exclamation degas bottle puking
I HAVE READ ALL OVER THE FORUMS AND CANT FIND A ACTUAL ANSWER TO MY SITUATION U GUYS HAVE A LOT OF GOOD ADVISE.... 2007 F550 WITH 60,000 MILES NEW MOTOR OUT OF A 250 VAN EGR DELETE NEW OIL COOLER NO STUDS ECT EOT WITHIN 5-6 DEGREES EDGE W ATT RUNNING NO TUNE JUST USING FOR GAUGES I PULL A 53 FT RACE CAR TRAILER FOR WORK.....PUT AROUND 3000 MILES A WEEK ON TRUCK RARELY DROVE WITHOUT TRAILER BUT WITH NO TRAILER ON IT NEVER LOOSES WATER EVER.....BUT WITH TRAILER ON IT SOMETIMES WILL GO DAYS WITHOUT LOOSING COOLANT AND THEN LOOSE A GALLON OR SO AND IS FINE FOR DAYS AGAIN.....REPLACED CAP SEVERAL TIMES THOUGHT IT WAs WEAK .... ANY IDEAS THANKS IN ADVANCE LOST
gdcoker is offline
post #2 of 30 Old 11-26-2012, 07:46 AM
ZMANN's Avatar
Quoted: 1354 Post(s)
first tip is don't type in CAPS
makes it a bit.ch to read
I would get a pressure gauge tee'd inline to the degas bottle and see if the psi spikes
how New is the Used motor ? what year is on the valve cover pass side ?
We Miss you Ronnie
ZMANN is offline
post #3 of 30 Old 11-26-2012, 08:53 AM Thread Starter
gdcoker's Avatar
2006 year on motor had 55,000 when it was installed put about 18,000 on it
gdcoker is offline
post #4 of 30 Old 11-26-2012, 09:01 AM
Quoted: 348 Post(s)
Feedback Score: 5 reviews
Bad coolant bottle cap (seems you already tried)
Ruptured EGR cooler (you have an EGR delete so it is not the cause)
Bad Head Gaskets (im afraid 99% this is your issue)
Those three symptoms are what cause coolant to puke...
I would get exhaust in coolant test strips and test the coolant in your bottle, that will tell you if HG are blown
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #5 of 30 Old 11-26-2012, 09:09 AM Thread Starter
gdcoker's Avatar
im not sure what its called but i had a buddy of mine do the blue liquid test
(sorry ) not sure what its called but it did not change color do the test strips work better??
gdcoker is offline
post #6 of 30 Old 11-26-2012, 09:12 AM
Quoted: 348 Post(s)
IDK....
I have never used them but they are most popular and can be found in most Auto supply stores (Napa)
I would triple check as they are less expensive then starting to throw parts at it!
Studded and Deleted
post #7 of 30 Old 11-26-2012, 09:16 AM Thread Starter
gdcoker's Avatar
ill stop by and get some thanks maybe someone else can shine some light
gdcoker is offline
post #8 of 30 Old 11-26-2012, 01:49 PM
southend's Avatar
What are your ect snd eot's. Could it be overheating from a bad water pump?
Sent from my phone that somebody didn't help me get.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #9 of 30 Old 11-26-2012, 01:54 PM Thread Starter
gdcoker's Avatar
at the most my temps are 220 but stay closer to 206 or so i did buy a hd fan clutch im getting a code now for fan speed sensor circuit
gdcoker is offline
post #10 of 30 Old 11-26-2012, 01:59 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Nobody asked this and it is very possible. How high are you filling the coolant level in the degas bottle? The new revised MAX line is about 1/4"-1/2" below the OLD MIN line. If you over fill it - it can cause it to puke coolant.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
