6.0 Rough Start, Now No Start??? FICM??? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 11-24-2012, 10:08 AM Thread Starter
Hey guys, I'm in a little bit of a dilemma here. I have an 03 6.0 F-250. I'd like to say my problems seem to have started after my last oil change, I switched from Rotella to Delvac. After the oil change, I had alot of chugging after a cold start (by cold I mean 30-65 degrees outside), never had this problem last year, even in sub zero temps.
The other day, drove it to work where it sat overnight about 25 degrees out. Went to start it in the morning, cycled the glowplugs as usual and it kicked over then stalled. Tried it again and it would do the same thing over and over. It was puffing black smoke out the tailpipe when cranked. Came back later on and pushed it inside a garage, plugged it in (for the first time ever), put a space heater under it and after a few attempts it started. It was still running rough up until that point with the Delvac in it.
I figured after that it could very well be the oil and maybe even fuel filters. Today I drained the oil, put the Rotella 1540 back in and changed both fuel filters. After changing the fuel filters I cycled the fuel pump a few times before starting. Once it started there was no change in the way it ran, even put an additive in the fuel in case I got $h!t diesel. Once it hits about 2000RPM, it puffs blue smoke, and there is definitely a noticable miss and lack of power.
A buddy of mine suspects a bad FICM, and reading some of the forums on the net it seems like a distinct possibility. On a side note, I have had a battery light on the dash, however I'm getting between 13 and 14.7 volts at both batteries and the alternator, but I don't know if that could cause a low voltage condition for the FICM not to work. I did test the FICM using a volt meter, I had 47v with the battery off. I had the wife come out and crank the truck over to test the volts while cranked and running. Welp, it wouldn't even start, and I had huge fluctuations in voltage while she cranked it over.
My best guess is the FICM is bad, but its just strange considering all the circumstances and figured someone at there has had to have some experience with it. I don't have access to a scan tool, but when it was stranded at work the other night, I did have access to one and it threw no codes.
Don't want to buy the FICM if I'm not sure its the problem. Thanks in advance guys!
jmisbpd is offline
post #2 of 13 Old 11-24-2012, 10:57 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
What did the voltage drop to when cranking?
dhanna6powerstroke is offline
post #3 of 13 Old 11-24-2012, 12:38 PM Thread Starter
Dropped to about 38 when cranking. Called a buddy of mine a ford mechanic; had me heat the housing with a propane torch and try starting. It started right up, he said definitely the FICM. Just got a preprogrammed refurb from northern auto parts for $483 including shipping and $200 core. Thanks for the reply!
jmisbpd is offline
post #4 of 13 Old 11-24-2012, 01:11 PM
Mod Newbie
Quoted: 20 Post(s)
I would have went with the upgraded unit from Swamps vs. a stock replacment. Almost same price and 58v upgrade
post #5 of 13 Old 11-24-2012, 01:14 PM Thread Starter
Yeah I looked at those I'm probably getting rid of the truck soon after I get it running though, ha
jmisbpd is offline
post #6 of 13 Old 11-24-2012, 02:16 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Should I feel bad that I am hoping its not the FICM....
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 13 Old 11-24-2012, 03:00 PM Thread Starter
Haha why is that give it to me straight!
jmisbpd is offline
post #8 of 13 Old 11-24-2012, 06:35 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
It just bugs me how many of these trucks get bandage'd back to running and then the guy sells them off to a unknowing"sucker". This just gives the truck a worse name than it did before which lowers the value of all these trucks even more.... I may be way off base and juz have a hair up my azz.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #9 of 13 Old 11-24-2012, 06:59 PM Thread Starter
Nah I'm doin the FICM new batteries and an alternator and I'm so torn about getting rid of it because I actually like it. I'm just not big into the mods, for me anyway. I like keeping it close to stock. I just feel like if I start dickin around under the good it will only lead to more problems. I really can't complain, I bought it for 12k and it had 84kmi on it, it's an fx4 lariat supercab. So if I have to sink a few bucks into it I figure I'm still ahead of the game. Don't worry Brotha no bandaging goin on here
jmisbpd is offline
post #10 of 13 Old 11-24-2012, 07:17 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 466 Post(s)
Garage
Amen to that kinnisoj ( hows the pine tree mod working for you LMAO), Pisses me off when guys jump on the forum and gripe when the truck won't start or left them stranded.
When you start getting the picture that the oil is changed every other year and the coolant is 7 years old from the factory and their mad that the oil temps are 40 degrees delta!?
This Powerstroke is a precision computer dependant engine with lots of new technology new to diesel industry. It needs to be treated as such, if it's maintained it is a fabulous engine with gads of power for its displacement.
It's a crying shame that it's been labeled a lemon mainly from tuner abuse and lack of taking care of it. I feel it's the best looking body style hood combo head lights ect Ford has made, even like them more than the 2012 for sure.
My truck has never made me walk and I will have it for years to come, hell the truck I had before my present 06 I had for 24 years. Only have 18 years to go.lol
Back to this guys issue: check both your batteries seperately with a load tester then check alternator output after 2 minutes from start. Ficm,s rarely just go out, odds are your batteries are shot or alt is bad or your cables are corroded up and power is low!
FICMREPAIR.COM will rebuild yours better than it came for a few hundred dollars IIRC.
$483.00 is really getting into your knickers..............choice is yours but you better figure out what killed it !!
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
