Injectors, now long crank
Well i replaced all my injectors and now I have a long crank after you let it sit. If its running and you turn the truck off for a second and start it again, it seems to be ok. After just 15 minutes it takes a long time to crank and start. The truck runs great after it starts. I also did the blue fuel pressure spring upgrade.
Before i did the injectors it would start rather quickly. I would notice the engine would start before the oil pressure gauge came up at all, and now it cranks for so long the oil pressure gauge raises then the truck starts. Any suggestions would help, I work an 4-12 today and need to get it fixed tomorrow, which would be a difficult task being a sunday. |
How many miles on truck since injectors were replaced?
I would suspect one of the upper injector o-rings are causing a hpo leak, just a guess though.
You need to monitor your ICP pressure while cranking and idle,2000 rpm,s Also IPR values to see if the percentage is above normal to make up for a leak in the system. Possible it's a ficm issue just not as likely as hpo or fuel pressure issue. |
The injectors have maybe 3 miles on them, i just did them yesterday. I will be installing a new IPR valve and ICP sensor tomorrow and then see if that fixes the issue. If not, Most likely ill be ripping it back part to remove the high pressure oil web to check the o-rings. What else could i check while in there? I dont have a scanner/monitor which sucks, i'll just do what i can and try and find someone with a scanner if i dont fix it.
Almost 2 years ago now the dealer installed a new HPOP, do you think they would have replaced the STC oil fitting when in there? I am not sure, the RO doesnt say anything about it. |
Drive s**t out of it. You have a lot of air in the system which causing your whole problem. Will take a while to get all the air out.
dhanna, ill try this, how long should i do this to see if the long start doesnt go away? It is running so good now, i really like it, but it was a huge bummer when it wouldnt start like it should. I hope running the piss out of it helps!
I guarantee it will get better. It's gonna take a good amount. Go on a good 20-30 mile drive and see what happens. Also, if your truck is an 04, it doesn't have the STC fitting. Make sure you're using Motorcraft oil filter and factory cap too. That will contribute to a longer crank but I'll almost bet money you still have a ton of air in the system.
You still shouldn't have the STC fitting.
Ok, thanks
