1700rpm powerloss/vibration...injectors?
When cruising on the highway i will get a power loss and a vibration at around 1500-1700rpm doing about 50-60mph. Vibration just started about a week or so ago and doesn't always happen. But the power loss at those rpms is becoming more frequent and almost constant now whenever im at that 50-60mph mark. I also have been seeing a huge drop in MPG. I was thinking maybe injectors?
Sounds about right. Mine did the same thing and I never broke 17 MPG on the highway and rarely seen above 12 in city/combined driving until I got my new injectors when I did gaskets and studs. Jesse explained to me that it was spool valves on the injectors that fail and cause the hesitation and bucking at 50-60 mph.
Very well could be injector related. However I would rule out batteries and FICM first before diving in and replacing the injectors.
Good news is i am under warranty, bad news is i called my tech 2 days ago after guys on here responded with it being the ficm and my tech said its almost impossible for them to cover a ficm even with the warranty? he said like 9/10 guys have had to pay out of pocket? ive heard the ficm will still test ok even if it is shot? this could be it since i ran a scangauge2 on it yesterday and my volts were fine. Batteries tested fine about 3k miles ago at ford when it was in for service.
Well I would take it to them then and have them diagnose it. If it's injectors or FICM they should be able to tell.
Mine did that with a bad injector, including a rough idle.
Sent from my phone that somebody didn't help me get. |
Got an appt with ford for next week...ill keep everyone updated
Just went out to start my start after sitting for 10hrs and had a horrible almost clunking noise coming from the motor for the first 30-45 seconds but the weird part is it cranked over right away in almost a split second?
Mine had the same misfiring vibration/bucking at the same RPM range and roughly same speeds. A decent 6.0 diesel repair truck shop found a misfiring injector and replaced it roughly 14,000 miles ago. I have had no problems since with injectors... knock on wood. But after replacing the injector, i had a clogged oil cooler, which i ended up at the time running too hot of oil to my injectors causing the injector failure. I have since cleaned and changed coolant, and oIl cooler, and deleted EGR system for longevity purposes. I Do not believe you need to replace ALL injectors if need be. They only replaced 1 of mine and it fixed the problem. Although if they dignosed a bad FICM it might be another story..
