Continued diagnosis...........opinions - Ford Powerstroke Diesel Forum
Old 11-21-2012, 10:39 AM
Continued diagnosis...........opinions (UPDATE_FIXED)
So got the p0500 ABS light and no speedo. Replaced VSS, rear output shaft sensor and checked wiring for breaks all the way up the the male termination point by the battery with positive continuity. Am I to assume at this point the only other thing it can be is the cluster???? Thanks for any help guys.
Old 11-21-2012, 12:23 PM
Well it could be the module but ya still have to change the cluster since the module is integrated into the cluster.
Old 11-21-2012, 12:42 PM
Whats odd is that its still throwing the P0500 code and Ive replaced the VSS, and shaft sensor and wiring is good. But since the code is there that would lead me to believe its not the cluster...............thoughts?
Old 11-21-2012, 04:39 PM
You did clear the code after the repair right?
Old 11-22-2012, 06:46 PM
Yep code cleared...
Sent from my iPhone using AutoGuide.com App
Old 12-10-2012, 08:32 AM
Theres not a ton of info on this so I wanted to share my fix. So i dropped the truck off to my buddy whos a ford mechanic. Had it back a few hours later, apparently there was no ground to the ABS module, it was a bad ground on the core support. He fixed it and everything is good now.
Thanks fellas.
Old 12-10-2012, 09:32 AM
Glad it was something simple, didn't even think about the ground sorry.
Old 12-10-2012, 09:35 AM
Thx for the help
