Fuel Supply Line Leak between line segments - Ford Powerstroke Diesel Forum
Old 11-21-2012, 07:49 AM
Folks, I have a 2005 Excursion 2WD 6.0L with 57k miles. The fuel supply line between the pump and the secondary filter is leaking, a slow drip, at the coupling where the two fuel segments meet. The Ford does not offer a replacement o-ring for the hose, they want to replace it as an assembly. Do I really have to replace the lines????. Or is there a driveway repair I can make?
Thanks ahead of time for any help.
This web site is an invaluable tool!!!
Old 11-21-2012, 12:38 PM
Not sure I can help, but a picture would help.
Sent from my phone that somebody didn't help me get.
Old 11-22-2012, 01:35 PM
I will try to get a picture of the connection, I will have to disassemble it to get a good view. It is under the Air Filter, the drivers side front corner of the engine, at about cylinder head level. It is a fuel line to fuel line connection. I just can't believe that Ford considers it a non servicable connection, they want to replace the hose from the pump to the fuel line segment that goes up to the fuel filter.
Old 11-22-2012, 01:38 PM
Recent thread on truck catching fire and burning to the ground. This page of that thread has a nice shot from Tuscany of the fuel lines near where you are talking, I think.
6.0 catches fire
Old 11-22-2012, 01:57 PM
6.0 catches fire
Yep, i'm watching that one.^^^
Old 11-22-2012, 02:05 PM
I'm not familiar with those connections.
Old 11-22-2012, 02:07 PM
If you happen to need new line or lines, could you post up the part#s for us. I know quite often folks will twist their fuel lines when trying to do the blue spring update. (almost can read the number on Tuscany's photo)
Old 11-23-2012, 07:45 AM
Good catch Amdriven2liv,,, Thank you!
This shot captures the lines and the connection, look in the lower center of the shot, on my vehicle the upper connection is leaking, I assume it is fuel supply line and the second line is the fuel return line. Looking for a part number on the hose, I will have to go to the dealer to get it.
OK, so, twisting the lines while taking them off is bad...
Old 11-23-2012, 08:04 AM
In most parts houses there is a section where they have Lisle/Dorman help products, fasteners; gromets; body screws etc. There are several different size repai kits o-ring plus the little spring retainer for these pushlock fittings. I have used those before.
Tags
fuel line, leak
