04 6.0 Turbo Troubles (please help) - Ford Powerstroke Diesel Forum
Old 11-19-2012, 01:33 PM
I have an 04 6.0 that has 135,000 miles and is still completely stock (motor wise). I am experiencing intermittent turbo issues. I usually experience it when I first get in it to drive, doesn't really matter whether it's overnight, or just been sitting for 15 minutes. The turbo will sometimes not engage until I am going about 30mph, then it will make a chirp/ whistle sound and engage, then it is fine sometimes, but sometimes it will do it again if I stop @ a light. Other times it will not engage @ all for the length of my trip, but I have found if I am going down the road and put it up into neutral and just turn the key off & back on & restart, then the turbo will kick in, like it is an electrical issue with something not engaging it. I took it to a shop & got an oil change and they checked it out and said the truck was needing several program updates which they did, but my problem continued after I picked it up. Help, suggestions, comments????????
Thnx!
Old 11-19-2012, 02:12 PM
Sounds like the unison ring is seized, not uncommon. Time to take it off and clean it. Check for loose/torn cac boots, and exhaust leaks first.
Sent from my phone that somebody didn't help me get.
Old 11-19-2012, 03:41 PM
Send a message via Skype™ to Bluedemon6.0
Tousley Ford, turbo cleaning kit. It is like 50 bucks or a cleaning kit from 3m with drill attachments. You tube turbo cleaning 6.0, pretty easy to do.
Sent from my PG06100 using AutoGuide.Com Free App
Old 11-20-2012, 11:50 AM
Thnx for the 411.
So is it fairly easy to remove the turbo and take apart & put back together?
Old 11-20-2012, 11:58 AM
Depending on your mechanical skills allow 4-8 hours. "Srmastertech" has some great detailed vids on youtube.
Old 11-20-2012, 12:01 PM
Awesome thnx, I'll check it out & see if it's within my limitations or not.
Old 11-20-2012, 02:36 PM
Is the truck a early or late build motor?
Look on the passenger side valve cover for the ICP sensor. In this picture is my ICP there, which means my 04 is a late build motor. You might want to update a couple parts while you are in there.
