6.0 code help - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-17-2012, 11:45 AM Thread Starter
6.0 code help
here are some code my truck is throwing can yall explain that the codes r and what could be the cause of them p0281 p0197 p0683 p1000 thank yall for the help
meche2326 is offline
post #2 of 4 Old 11-17-2012, 12:41 PM
information regurgitator
NYC F-350's Avatar
Quoted: 51 Post(s)
P0281: Cylinder #7 contirbution/balance
P0197: Engine Oil Temp Sensor Circuit Low Input
P0683: Glow Plug Control Module to PCM Communication Circuit
P1000 is basically that the truck was not running long enough to run all the tests, not a big deal.
It seems you have an electrical gremlin somewhere in your electrical system.
Please
You could save the life of a sick child
NYC F-350 is online now
post #3 of 4 Old 11-17-2012, 01:20 PM Thread Starter
the truck ran hott and it didnt show it ever ran hot the truck would miss here and there at idle so im sure the number 7 injector is going out right?
post #4 of 4 Old 11-17-2012, 01:24 PM
Yup time to break out the dvom a good flashlight and the wireing schematics and chase them gremlins. Pesky little things can cause all kinds of havoc in a electrical system.
Your injector may not be bad it may not be getting a signal from the ficm to work [wireing or FICM problem]
You could have striction issues [spool valve sticking due to a hp oil problem] Only proper testing will tell.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
